whats the best scope to use ith a SM90II etalon and BF30?
As i said in the topic title, i am interested in what people have to say on what the best scope/etalon combination for this?
Just Learning
- pedro
- Has thanked: 14 times
- Been thanked: 6696 times
Re: whats the best scope to use ith a SM90II etalon and BF30
I used a pre-meade SM90 with a TV101 F/5.4.
This Etalon is now sold but I will have a SM60 (also pre-meade) soon that I will use with the same scope for FD imaging. I will use it with a Coronado BF10 and a LUNT B1200
Pedro
Pedro
Pedro Re'
- solarchat
- Site Admin
- Has thanked: 84 times
- Been thanked: 1387 times
well, the best scope to use with that etalon/BF combination would be a single etalon Coronado 90mm internal etalon scope, in my opinion.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
solarchat wrote:well, the best scope to use with that etalon/BF combination would be a single etalon Coronado 90mm internal etalon scope, in my opinion.
ok so you are suggesting that I purchase a Coronado 90? well here in Australia they are a small fortune - that's why i jumped at the chance of getting the etalon for 3.5k. a dedicated 90mm scope with bf15 is 5k, with a 30BF its 6k and DS is 9k. I was thinking i could have mounted it on another scope or my existing large refractor but i take the point
Just Learning
- solarchat
- Site Admin
maybe I didn't understand the question..
If you already have an external Coronado 90 filter and want to put it on the "best" scope possible, I suggested the Coronado 90mm internal etalon scope. Then you would end up with a doublestacked 90.
Do you mean which of your current scopes would be best? What are your current scopes?
Stephen W. Ramsden
Atlanta, GA USA
Atlanta, GA USA
Hi David
I would mount it on a TAK102
far too many scopes all at the low end, 127ed ed80's 14" meade acf, 11 celestron, 8 inch meade ACFsolarchat wrote:maybe I didn't understand the question..
Just Learning
thanks Walter, do you see these 2nd hand much?swisswalter wrote:Hi David
Just Learning
Hi David
from time to time ther is one up on astromart or Astronomie de or astro inof
The best telescope for using a Ha 90mm external etalon is a telescope with minimal spherical aberration at this wave length.
Among compact telescopes are:
1. Synta or Made 102mm F/10 simple achromat. Any of them. Will work better than any TAK doublet apochromat.
2. Meade AR 129mm F=1200mm will work even better. But it much less compact than the scopes above.
Valery.
Valery.
well I am learning stuff all the time, thanks. i was thinking of and extra scope to image with , you know when the sun goes downValery wrote:The best telescope for using a Ha 90mm external etalon is a telescope with minimal spherical aberration at this wave length.
Valery.
Just Learning
well i went ahead and visited my local machine shop - $300 later and i will have within 2 weeks an adapter for the 127ED to take the SM90. mind you though for the chunk of metal its a very expensive adapter
Just Learning
Houghy wrote:well i went ahead and visited my local machine shop - $300 later and i will have within 2 weeks an adapter for the 127ED to take the SM90. mind you though for the chunk of metal its a very expensive adapter
Hi Dave
yes I wonder too. 1 KG of my stuff is sold for maybe 30 $, 250 g of formed metall is sold for 300 $. Next time I come down to earth . I'll get me some metal and a lathe
i updated the above post to include the design of the plate
Just Learning
- Has thanked: 20828 times
- Been thanked: 10501 times
Nice plan!Houghy wrote:i updated the above post to include the design of the plate
well i hope it works - and functions as it should. so should i paint the outside white?marktownley wrote:Nice plan!Houghy wrote:i updated the above post to include the design of the plate
Just Learning
Will your adapter plate be thread into dew shield?
Aleksey
Lunt LS100THa, Coronado SolarMax II 90 Filter + BF 15 on WO Megrez 90, PST + SW 1025 mod, Quark + SW150/750 in test mode
yes directly into the shieldRybak wrote:Hi
Just Learning
Houghy wrote:yes directly into the shieldRybak wrote:Hi
Hate to say it Huff mate, but if I understand your "yes directly into the dew-shield" I reckon you'll be disappointed.
The SM90 x 2 is huge, and more to the point HEAVY, it will tilt the dew-shield depending on the orientation.
The SM60 setup I had worked on the FS78 scope, and it meant removing the dew-shield completely, and attaching directly to the "ring" that the dew-shield screwed onto. This was rock solid, and introduced no tipping/tilting whatsoever. (I still have the SM69-FS78 fitting if there is anyone out there that wants one).
One way to find out though, expensive way, but you'll know soon enough.
Gary
I only have one Sm90?gbealnz wrote:Houghy wrote:yes directly into the shieldRybak wrote:Hi
Gary
Just Learning
I use DIY adapter plate on my Skywatcher 102 mm f5. And I control the tilt of adapter plate by GMK collimator.
- CIMG6002 [800x600].JPG (136.08 KiB) Viewed 4825 times
Aleksey
Correct me if I'm wrong but aren't the Meade the same as a Bresser for $795 looks good to me and no way would I hang a SM90 off a dew shield.Valery wrote:
Valery.
http://www.astroshop.com.au/products/de ... d=MAS-031B
Or a 152mm for $1175
http://www.astroshop.com.au/products/de ... d=MAS-031C
Alan
Only paid $180 for this adapter, your machinist is very expensive David.
Alan
Nice setups chaps!
Thanks Mark.marktownley wrote:Nice setups chaps!
Alan
