LuSol-Guide, software for solar autoguiding
Hello,
I open a new post to announce the first version of my solar autoguiding software. It has been tested with various cameras and mount, but maybe there are still some bugs...
So you can (must!) download first the evaluation version, and after if all is ok, you can buy the complete version.
All is here :
http://www.oc-lab.fr
feel free to contact me if you have remarks, questions etc...
Olivier
All is here :
Olivier
Re: LuSol-Guide, software for solar autoguiding
Hi Olivier
that is interesting. Does it work with a Losmandy G11?
Hi!
The software works with mount compatible with ascom so i think it will be ok with losmandy/gemini:
http://ascom-standards.org/Downloads/ScopeDrivers.htm
Other possibility is to connect the mount through ST4 port and GPUSB interface.
For future development, maybe I will try to use st4 port embedded in few guiding camera.
Olivier
Olivier
Thank you Olivier
feel free to ask me any questions and don't hesitate to test the evaluation version. You could be verify if it is ok with your mount.
Bye,
Olivier
Bye,
Olivier
Hi olivier
thank you very much. Yes I'll download the trial version and will see how it works with my mount
Hi, i have tried to download your software and tried to use it with a camera qhy MZ5M and qhy5LII.
The software is not able to find any camera i use, the only camera in the menu is the webcam in the computer. The software is able to work with this cameras?
They have also an ascom driver...
Re: LuSol-Guide, software for solar autoguiding,
Hi Lorenzo,
Sorry for this late reply. I have sent you a private email to discuss about the problem. In few word, normally LuSol guide should work with qhy2 if the last wdm driver are downloaded and installed from the website of qhy.
I am interested by your experience and if your camera is well found by the software with the last wdm drivers.
Thanks,
Olivier
Thanks,
Olivier
Hi.
Did any one test this program on a Losmandy G11?
"I'm enough of an artist to draw freely on my imagination. Imagination is more important than knowledge. Knowledge is limited; imagination encircles the world."
--Albert Einstein, October 26, 1929
EQ:
Double stack 60mm Coronado ( pre-meade ) H-alpha filters with a 15 blocking filter.
DMK 51AU02 the imaging source Mono CCD camera.
Orion Short 2x Barlow.
Explore Scientific 102mm f/7 Air-Spaced Triplet ED Apochromatic Refractor Telescope.
Astrotelescope ( Planet Killer ) 102mm f/11 hand corrected doublet. Refractor Telescope.
Losmandy - G11 ( Gemini 1 )
FireCapture, AutoStakkert 2, PixInsight, Registack 6 and Photoshop CS 6.
EQ:
Hi Herb
that is a good question. The answer will interest me too
Walter I think I'll be the guineapig for this I'll try the free one and I'll let you know.
EQ:
EQ:
Hi Herb
thank you very much. I look forward to your findings
Hello,
The more secure way is to test freely LuSol. I propose to download a trial version on the website. LuSol should must with all mounts compatible with ASCOM or just with the GPUSB interface (and in this case, you need just a mount with ST4 port). It seems to exist ASCOM driver for G11 so I think LuSol will work well, but I have not try it on this mount.
About camera compatible, LuSol should must work with all camera compatible with WDM drivers (almost all camera on windows !). Lusol was tests with different camera : simple webcam, DMK series, QHY, meade DSI.
Please feel free to test the software and let me know if you have remarks, questions or bad experiences with it. I would try to fix problems.
Thanks,
Olivier
Thanks,
Olivier
I'll try it soon.. And I'll try to post pictures.
EQ:
EQ:
Hi !
an new release of LuSol-Guide is available her : http://www.oc-lab.fr
few improvements and bug corrections.
Olivier
Olivier
Hi Olivier
thank you very much
thank you very much
Hi all !
just a short message to announce a new release of LuSol-Guide : http://www.oc-lab.fr
In this version, no improvements of the guiding, but additional options : french version, log file, RA guiding only.
Bye,
Olivier
Bye,
Olivier
Hi Olivier
thank you very much
thank you very much
Hi Olivier,
I have tried to use the software with a couple of Atik ccd without sucess (lusol don't detect it), did you use this cameras o do you know if there are some problems with their drivers and lusol?.
REgards
REgards
