Hmmmm
Just reading the manual for the new QUARK Ha system...
The recommended ambient operating temperatures are 40 -100 deg F (5 - 38 deg C)
May be an issue getting it "on band" on a typical Australian summer day....
Daystar QUARK - Operating temperature range
- Has thanked: 173 times
- Been thanked: 615 times
Re: Daystar QUARK - Operating temperature range
You are not alone! A lot of sunny days here are below 5C !!! So, we will need to make an outer additional heater!Merlin66 wrote:Hmmmm
And you need to make an outer cooler (much easier, with a can of ice! or Peltier ).
Valery.
Hopefully Daystar will answer our concerns......
I wonder if it will work in -30c,I'm thinking no,which is too bad because I was going to try one.Daystars answer will be very interesting
Gerry
SW 120ED Pro,90mm Stellarvue
Baader Cool wedge, Quark Chrom
