SM90 issue?
- DSobserver
- Been thanked: 19 times
SM90 issue?
Hello
I finally receive last week my SM90II filter that I use on my TSA102 scope.
I notice that, what ever the tunning, I couldn't achieve to get a full Ha coverture in the eyepiece : nearly, but not completely, only sun disk surface is able, when I properly place it, to be in Ha.
Outside it slowly goes to white light wavelength.
Is that normal for such filter?
Other point : did you notice any advantage with the richview system?
- GUS
- Has thanked: 102 times
- Been thanked: 213 times
Re: SM90 issue?
Hi, the rich view tuner can be adjusted by repositioning the pin at the front of the etalon a couple of holes one way or the other.The etalon was set for a particular elevation, which may be different from yours,so will need to be adjusted to be able to reach on band.I had to do the same on my SM60 II,about three positions .What I notice with my etalon is that tuning with the T max causes a band of detail(sweet spot) which moves across the disk.If I use the rich view, the sweet spot is more circular.When I set the pin,I made sure that the T max was nearly closed, and then adjusted the richview tuner to get close to on band,then refix the pin. Then i can use a combo of both to get on band.
NB.The T max is usually used for double stacking to get the ghost image out of the view.
Re: SM90 issue?
Hi Gus
that is my experience too. Use the t-max to get rid of the gost, fine Tuning with the rich view
- DSobserver
- DSobserver
Re: SM90 issue?
I could quickly try this this afternoon, and I think it works!
I need to check again during better conditions
- Has thanked: 173 times
- Been thanked: 615 times
Re: SM90 issue?
Richview tuning v's tilt tuning???
I have asked this question before....
On the ol' original SM60/90 external etalons (I have the SM60), the T max tilter screw brings the tuning from the red wing down through the "on band" and into the blue wing.
If the etalon is tilted to move the ghosts, then it would end up sitting in the blue wing (or beyond)
I therefore have to assume that the Richview tuner effectively reverses this effect of the tilt by reducing the gap between the etalon plates and moving the bandwidth back up towards the central "on band"
Is this what is actually seen? a move from the blue to the red?
Re: SM90 issue?
Hi Ken
that seems to me a very sound explanation to what is really happening
- GUS
Re: SM90 issue?
Hi Ken, that seems to be the case.I think this is also the reason coronado double stack filters( RICHVIEW) did not have to go back to factory for double stacking as the previous max scope/solarmax filters supposedly had to.There seems to be more tuning range with the RV tuner, and the T max is only really needed for double stacking. I can use a SM 60 II etalon on my other scopes without the T max and it works fine
Thanks.
GUS
Thanks.
GUS
Re: SM90 issue?
I've been using a pair of original SM60 etalons double stacked on the ED80 for the past few years.
They never went anywhere near Meade/Coronado for "double stacking alignment"!!!
The hardest part, other than achieving good tuning, was obtaining the adaptor ring to fit a T Max thread to the front of a SM60 etalon.
It would be interesting to know if the "two hole reset" is a consequence of the amount of tilt required to move the ghost image....
- GUS
Re: SM90 issue?
I went through three SM 60 II filters and one SM 40 II filter (due to the central obstruction coming loose)and each one of them was set differently for tuning.Some would not show any detail with the tuner until i used the T max opened nearly all the way, while others showed detail with the T max completely closed, or partially opened.The pin position allows for differences in altitude and probably in manufacturing tolerances. I remember reading the coronado manual that came with my Solarmax 40 scope with the older etalon and it mentioned returning to factory for DS.
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: SM90 issue?
The Richview tuning works in exactly the same way as the tuning with a PST etalon works. It even uses the same orange foam for the etalon to sit on and tilt...Merlin66 wrote:Richview tuning v's tilt tuning???
- DSobserver
Re: SM90 issue?
To get proper wavelengh, I had to move the pin 4-5 holes
Mark summarize it well : with the richview, I manage to get proper setting on the whole field (in my case the Ha view arrive from the north side to the south), same as in the PST
The T-max is now nearly close
- GUS
Re: SM90 issue?
Hi Mark, how does the richview tilt the etalon? The pin seems to press down centrally and the foam seems to be of even thickness.
Re: SM90 issue?
Etalons like this are wedge shaped, it is also pushing down on the perimeter aswell as the centre, when pressure is applied on the etalon it causes the etalon to tilt.
