First H-Alpha Solar Telescope - Question
thedoci
Oh, I get it now!
Oh, I get it now!
Post by thedoci » Thu May 29, 2014 7:17 pm
Hello you all,
i am not sure if this is the right forum section for this question, but id like some input form you guys as to my first H-Alpha Solar Telescope. This is due to me going to Denmark for a few weeks, to a part of the country with large body's of water on the east and west side. Thus seeing conditions should be rather good (I hope).
so here is a list of some telescopes in my price range:
- Coronado PST
- Lunt LS35 Delux edition
- Lunt LS50THA with B600 Blocking filter
- Daystar Quark with a Skywatcher Startravel-80 or 102(Black Dimond)
I intend to use the scope visually as well as for imaging.
I would like to know your opinion as to which of these scopes i should get. Or if you have suggestions i am interested in hearing them.
Gear: GSO 150/750mm Newton, Old 68/1200mm Refractor, Baader Solar Film, Baader Continuum Filter, Baader L filter, Baader Q-turret Barlow, Sony A350, Sony HX-20, Point Grey Scorpion 13FFM, Point Grey Grasshopper GRAS-03S3M-C, Grundig FA85 I (CCTV camera that im having a play with)
Deviantart Galery: http://timelordomega.deviantart.com/
solarchat
Site Admin
Site Admin
Re: First H-Alpha Solar Telescope - Question
Post by solarchat » Thu May 29, 2014 7:46 pm
if you already have a nice refractor then the quark is a good choice for visual. if you don't have a really good refractor then there is no question that the LS50 is the best option.
None of these are made for imaging and I wouldn't want to recommend any of them for imaging. If you can only choose one of these then I would use the same criteria as above for visual/imaging.
The pressure tuned LS60 is optimal startup for imaging.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Post by marktownley » Fri May 30, 2014 5:47 am
Lunt LS50, no question.
Post by swisswalter » Fri May 30, 2014 3:20 pm
Hi Lukas
I would start with the PST and then later on mod it to your refractor ;)
thedoci
Oh, I get it now!
Oh, I get it now!
Post by thedoci » Sat May 31, 2014 4:32 pm
Could the Etalon of the LS50THA also be used in a similer way to the PST's etelon? I was actualy thinking about moding a scoep for solar work, i was thinking of buying a Lyra 102mm F/11 Refractor and then moding it with some Etalon and a Baader ERF.
Also to solarchats comment that the LS60 is better for imaging, i asume that this is because of the larger optics, but is the bandwidth of the Etalon also a reason for this.
Also, say i wold go with the LS60, should i go for the B600 or B1200 version
Also creating things on a lathe isn't a problem for me, so creating some adapters to get the Lunt Etalon onto some other scope wouldn't be that difficult.
Alternatively i could save up for a larger solar scope or even a DayStar or SolarSpektrum Etalon + Lunt blocking filter + Baader ERF
Also i have a question, would a mod (regardless of the etalons origin) benefit from using a APO refactor, such as the Skywatcher Esprit, or will say a Lyra or TS Refractor be good enough
Also Walter, i couldn't use my Refractor, as i have 2 problems with it. The first problem is that it is too heavy for my mount to handle, its essentialy a chunk of steel and it would exceed the already optimistic payload limit set by Skywatcher. And the second is that it has a star diaginal permanently mounted to the Focuser, the diagonal is literally part of the focuser (they are the same piece of metal)
Post by swisswalter » Sat May 31, 2014 9:48 pm
Hi Lukas
if you go with a LUNT60 then take the B1200 blocker. All my mods work perfect with simple FH, there is no need for a APO
a pic from today
thedoci
Oh, I get it now!
Oh, I get it now!
Post by thedoci » Sat May 31, 2014 11:19 pm
Whith what configuration that image taken? That is a very nice image!
Post by swisswalter » Sun Jun 01, 2014 5:57 am
Hi Lukas
with a simple 127/1200 FH , called "Skywalker" and the PST mod
thedoci
Oh, I get it now!
Oh, I get it now!
Post by thedoci » Sun Jun 01, 2014 1:28 pm
Well, i think i will go for the PST then.
Post by swisswalter » Sun Jun 01, 2014 6:42 pm
Hi Lukas
you can't be going wrong. Two ways to use it, first as it is and then mod it ;)
Sungazer
Post by Sungazer » Wed Jun 18, 2014 7:44 pm
Hi Lukas, Without doubt the PST is a very good scope ,and can later on be used as a very nice mod. I have used mine for many years, with excellent views. .All the best, John.
ForrestLockhart
Oh, I get it now!
Oh, I get it now!
Post by ForrestLockhart » Fri Jul 11, 2014 9:42 pm
Hi Lukas,
I have a Lunt 60, but on trips where a quick solar look in the morning is all I can hope for, I borrow our club P.S.T. It works OK on a light tripod, is compact, and provides good views of ol' Sol.
If you decide with the LS60, SwissWalter's advice to go with the B1200 blocker is very sound.
Forrest
Forrest
Lunt LS60T, TeleVue NP-101 refractor, 100mm Lunt Engineering refractor, 80mm StellarVue refractor, Lunt Herschel wedge, full aperture solar filters
thedoci
Oh, I get it now!
Oh, I get it now!
Post by thedoci » Sun Aug 17, 2014 12:08 am
Well i recently came across the double stacked version of the PST, would it be worth the extra money to get a bandwidth of 0.5A instead of 1A. Ive seen a picture from Alexandra with here DSPST. And i must say, they are more epic then the simple PST images.
Additionally, could the SolerMax eternal Etalon be used in a solar scope mod, as the diameter is much larger then the PST's internal etalon?
Also i have decided to get a PST, regardless of which type, DS or non DS. And i will not mod it, i will however maby get a second one (nonDS) for modding purposes, if the front etalon of the DS PST cant be used.
If im wrong with the PST DS having a external Etalon, then pleas correct me.
Post by Merlin66 » Mon Aug 18, 2014 2:18 am
The SM40 double stack etalon is a front mounted etalon.
To use it as the basis for a "mod" it needs additional optics - Check out the MARCON design....ends up a bit bulky and heavy....
Users browsing this forum: Montana and 2 guests
