I have an older Coronado Solarmax 60 scope and I am wondering if you can double stack it with the SolarMax II 60 mm double stacking etalon (SME-60)? The scope does have a thread on the front of it so I would think this will fit.
Can anyone confirm that the Solarmax II etalon fits on the older "Mark I" scopes?
Double stacking an old Solarmax 60
Re: Double stacking an old Solarmax 60
Hi Kdconod
welcome to that wonderful site. Have fun in the sun. I'm sure you will get very soon answers to your question.
- Been thanked: 10489 times
measure the threads on the front of your scope, then there is post in the solar reference library talking about the thread size on the SM60ii etalons. You should have all the info you need there.
Thanks that's very helpful - alas I do not have a thread gauge handy. I was hoping to hear from someone who has already tried to fit the mark II filter onto a mark I scope.
- GUS
- Has thanked: 102 times
- Been thanked: 213 times
Hi, don't know if this helps but I needed an adapter to fit an SMII 40mm DS filter to a early model solarmax 40 telescope. The SM II filter threads were smaller than those on the scope filter.
What do you mean by smaller? The diameter of the threads was smaller or the pitch of the thread is different?
- GUS
The diameter of the T-max thread was smaller than the older Solarmax filter threads, there is about 2-3 mm of play,it is stepping down from the older SM filter to the newer SM ll filter.The first photo shows the SMll stacked to the solarmax scope with the adapter.The second photo shows the adapter.The third photo shows the older SM filter taken off its T-max unit,(in the case of the 40mm scope the objective lens is attached to the T- max unit), the newer filter(minus its t-max) is then installed on the T-max unit attached to the scope.Then you install the remaining T-max on the older filter and this attaches to
newer filter now without needing an adapter.I do not know if this is similar to the 60 mm scopes and filters,but when I bought a SMll 60 mm filter set, I inquired about a similar adapter ring which I wanted to use as a lock ring for the filter attached to a metal scope dust cap, and was told that they are available.
GUS
GUS
