How are people finding the Quark?
cshahar
Post by cshahar »
I am thinking of buying one and a 110mm refractor, but a search of this and other forums reveals mixed results. I was hoping to get some feedback from users. It seems that it is difficult to get sharp images with the quark. Please let me know your experiences. There was quite a buzz when this filter first came out, but I am hearing much less about it now! I am still open to buying a dedicated solar scope, but was hoping the Quark lived up to its hype!
Thanks for your insights,
-Charles
grimble_cornet
Been thanked: 47 times
Re: How are people finding the Quark?
Post by grimble_cornet »
I am on my second Quark (first returned with banding issues) and am very impressed.
It is intended as a visual 'toy' so imagers are pushing the boundaries and learning as they go.
Daystar suggest f30 is the optimum which means that f6-7 refractors are ideal when combined with the x4.3 telecentric built into the Quark.
Here is a table summarizing my experience and that of another member (Solarhound) with different scopes:
The Quark seems to be quite sensitive to seeing conditions (not surprising with a x4.3 magnification factor) and there are lots of variables to consider (tuning, camera settings, use of focal reducers etc.) but I have produced a few images which make me smile.
This is probably my best so far using the Equinox 120 without reducer:
This is a rather nice prom shot with the same kit:
Eq120 Quark Grasshopper 2014 1910 1005 ut colour 800px.jpg (193.03 KiB) Viewed 3217 times
And finally a couple of images from my Equinox 80:
Hope this helps?
Mike Garbett
cshahar
Post by cshahar »
Amazing images Mike! I am so impressed. You are one of the success stories for the Quark. I have some unanswered questions I would like to ask. Please excuse my naivete in the case of some of these:
1. Does taking images in urban settings affect solar images? You mentioned "seeing" conditions. Is pollution in the urban environment a factor? I would imagine heat rising from buildings would affect solar images, but do I need to go to the country to maximize my results?
2. I live in Canada, and therefore a cold climate. Is that a problem for the Quark, which needs to be heated to operate? In short, can I use it in the winter?
3. I plan to buy a 110mm refractor. Do I need an energy reduction filter or will a UV filter suffice? I think that's the cut-off.
4. Will a 2-inch focuser work on current quarks?
5. Most important: Have they ironed out their production problems by now?
Thanks a bunch,
-Charles
Been thanked: 1 time
Post by swisswalter »
Hi Charles
stay away from buldings, concrete, hot streets and roofs. Seek for gras or water.
A 2" focuser works perfect
I have yet to use it in cold weather, but I think that shouldn't be a Problem
a 110 mm gun is o.k.
cshahar
Post by cshahar »
Thanks Swisswalter. I appreciate the information!
grimble_cornet
Hi Charles. I have sent you a 'detailed' reply to your email :lol:
Mike Garbett
Has thanked: 156 times
Been thanked: 893 times
Post by Valery »
Mike,
I see your QUAK is exceptionally good, almost perfect. I believe that the best way to go is to investigate all the possibilities
of using Q with 120mm refractor.
Valery.
grimble_cornet
Thanks Valery. I managed to put it through most of the checks you suggested and was fairly happy with the results.
I now need some quality time in the sun to sort out optimum tuning, capture settings, use of focal reducer etc.
Unfortunately we seem to be locked into a long sequence of poor weather with low pressure systems, wind, cloud and rain constantly moving in from the Atlantic so........ watch for progress when things improve.
Mike Garbett
smerral
Has thanked: 13 times
Been thanked: 122 times
Post by smerral »
I love mine. I find it performs very well with my ST102 (even though it doesn't get a great write up in the above table). Here's an inverted filament shot done with a 0.5x reducer.
BRIAN
Caithness, Scotland.
Double stack PST, Lunt CaK B600, Daystar Quark Chromosphere
with Altair Astro 102 ED f.7 Refractor and 60 EDF f.6 Refractor.
Celestron Nexstar 8SE.
QHY5III678M
grimble_cornet
Hi Brian.
That is an excellent image :bow :beanie: :bow
I produced the table to record MY experience with the Quark as a guide for other users and was then contacted by Solarhound who added his experience to the mix.
If you don't mind, I would like to add your experience with the Skywatcher to the table to give a more balanced report for prospective users?
Mike Garbett
