Measured finesse of the Coronado SM60 etalon.
- Has thanked: 173 times
- Been thanked: 615 times
The attached graph was obtained with a Spectra-L200 (1800 l/mm) spectroscope.
The dispersion was 0.29A/pixel, resolution, approx. 0.7A
This shows the transmission "comb" of the SM60 etalon around the Ha wavelength. Where the "peak" is reduced, shows the etalon to be "on-band" to the Ha line.
Measurements indicate a spacing of 11A, and a FWHM bandwidth of approx. 1A
(The other transmission lines at either side of the Ha line are blocked by the final blocking filter when in use.)
Hope this is of interest.
- Been thanked: 10248 times
Re: Measured finesse of the Coronado SM60 etalon.
Very interesting indeed Ken! Do you have any solid etalons you could repeat the experiment on?
Mark,
You mean Daystar type?
No, only Coronado......
Hi Ken
fantastic measurement. Thank you for sharing
Thanks Walter.
It's an ideal way of checking (and confirming) the etalon performance.
I had thought the bandwidth was better than 1A.......
Hi Ken
it's like fuel consumption with cars. Paper is very forgiving
I was wondering how many people would say, Why are the HW about 1 Ang when it should be narrower.
Even thou the camera chip is .29A/pixal the spectrometer with that focal length can not resolve the bandwidth. It would take a 3/4 meter focal length to resolve that HW. So it does best it can and shows you at what wavelength the peaks are at. What surprises me is that at the zero (or bottom) of the curve they should all be coming to the same count in that small range of wavelengths. Not sure what that is about.
Mark W.
Mark W.
- IMG.pdf
- scan with a small spectrometer
- (670.63 KiB) Downloaded 122 times
I am wondering why the H-a peak is so small vs other peaks. So small transmission here!
Ken, Mark W., can you explain why?
Thanks,
Valery.
Thanks,
Valery.
Valery,
I didn't mention in the post, but this is a solar spectrum. The dark Ha absorption line is sitting in the transmission "peak" of the etalon therefore that one peak appears "lower".
If the etalon was sitting "off band", then the Ha absorption wouldn't show up, and all the transmission peaks would be similar.
HTH
HTH
Hi, I forgot to say that the etalon was about .7Ang wide. But the spectrometer has no problem resolving the 1nm bandpass. On the attachment to my last post
The spectrometer is an HR 4000 (Ocean Optics) with a 5 micron slit.
Mark W.
Mark W.
Mark,
Any chance of getting similar data for the Lunt etalons and their blocking filters?
There seems to be at least some differences between the Lunt and Coronado blocking filters......
Nice review Ken!
Thanks for sharing.
This might be interesting too http://www.astroshot.com/Solar/Solarmax60-analysis.pdf
Thanks for sharing.
Alex,
Thanks for that.
I was the one who posted it to the library
Thanks for that.
Hi Ken,
I don't think that I should post scans of other bandpasses that I didn't make.
I don't want to have any conflict of interest. I just keep the posts as another guy that likes solar.
Mark W.
Mark W.
Hi Merlin66,
From your discussion it appears that you used the sun as the light source.
Why did you not use a reference light source without spectral features like a high pressure arc lamp?
Cheers,
Gert
Cheers,
Gert
Gert Gottschalk, Ph.D.
Tri-Valley Stargazers, Eastbay Astronomical Society, WFS Berlin
Gert,
It was an opportunistic capture. I was testing an SM90 and used my SM60 for comparison.
If I were doing a "proper" analysis, yes, a Quartz lamp, full calibration with darks, flats and instrument response would be the way to go.
It was posted to show the members the etalon comb and typical spacing....
