Page 1 of 1
Analysis of Fabry-Perot mica spaced Ha filters
Posted: Sat Jan 10, 2015 11:11 am
by DSobserver
Re: Analysis of Fabry-Perot mica spaced Ha filters
Posted: Sat Jan 10, 2015 11:49 am
by marktownley
Thank you for that link, it is very interesting and shows exactly my experience with the Quark.
Posted: Sat Jan 10, 2015 2:12 pm
by Bob Yoesle
An excellent analysis!
I especially appreciated the citation of Gene Baraff's work on the importance of using properly optimized telecentric lenses matched to the focal length of the objective - something generally not fully appreciated with these filters -- and why DayStar rightly does not provide a FWHM figure for the Quark.
Posted: Sat Jan 10, 2015 6:59 pm
by swisswalter
Hi Vincent
thank you very much for the link. Tons of good pages to read, very informative
Posted: Thu Jan 15, 2015 1:39 am
by pbsastro
Bob Yoesle wrote:An excellent analysis!
Yes, very interesting. I will need to read it carefully, but that makes important to confirm the Baader telecentric ideal FL. Bob, you mentioned 800mm at CN. Can you confirm that? I will be using it with 1400mm which would make it only acceptable, not very good.
In any case I think the edge degradation should be determined on the field edge, not sun edge, as on most scopes (specially on the 1400mm one), we can't get the full sun.
Pedro
Posted: Sat Jan 17, 2015 8:17 am
by mdwmark
The data looks good to me. There is nothing magical about F/30. It was just convenient in the early days because most scopes where F/15. To get to .3Ang you are usually starting below that. But you really need to be F/45 or longer. You will not get to .3Ang at F/30 regardless what you start with. The mica etalon does have the advantage over an air spaced etalon for a larger (sweet spot) at narrower bandwidths because of the difference in index of refraction.
Telecentric versus collimated:
Telecentric may broaden out the filter but it will broaden evenly. A collimated beam is easier to design but there's a wavelength shifts from the center to the edge. The HW will be the same, the center wavelength changes(shifts blue). Which gives you the sweet spot you see with this design. The sweet spot will be less noticeable the broader the HW is.
This is just how etalons work.
Mark W.
Posted: Sun Jan 18, 2015 3:05 am
by Bob Yoesle
Hi Pedro,
That is the design focal length Mark Wagner provided - and he should know as the Baader telecentric units are made to be used with the Solar Spectrum line of filters.
Christian has posted another update to his first study, which shows once again the power of double stacking etalons, and how the CWL
shifts with tilt for a collimated system. As Mark has stated this shift changes across the filter due to field angle magnification:
http://www.astrosurf.com/viladrich/astr ... aystar.htm
In an optimized telecentric system, you only deal with uniformly
broadened band-pass based on the F/D ratio light cone. In a non-optimized telecentric system, you likely will face both band-pass broadening
and CWL shifting.
Posted: Sun Jan 18, 2015 8:53 am
by swisswalter
Hi Bob
thanks for the additional link
Posted: Sun Jan 18, 2015 5:02 pm
by Valery
mdwmark wrote:The data looks good to me. There is nothing magical about F/30. It was just convenient in the early days because most scopes where F/15. To get to .3Ang you are usually starting below that. But you really need to be F/45 or longer. You will not get to .3Ang at F/30 regardless what you start with. The mica etalon does have the advantage over an air spaced etalon for a larger (sweet spot) at narrower bandwidths because of the difference in index of refraction.
Mark W.
What must be the F/D of a telecentric system that Solar Spectrum 0.2A etalon will really deliver these 0.2A ?
Posted: Sun Jan 18, 2015 9:38 pm
by marktownley
I have to say Christians work on this paper is one of the best resources available for pulling things together mathematically in a way that has been discussed loosely on the web for sometime now. The more I digest it the more it makes me think.
Posted: Wed Jan 21, 2015 1:09 am
by pbsastro
Bob Yoesle wrote:Bob, you mentioned 800mm at CN. Can you confirm that? I will be using it with 1400mm which would make it only acceptable, not very good.
Hi Pedro,
and CWL shifting.
Thanks Bob. Then I think I will go with an optimized telecentric for my 1400mm refractor. The Baader will be good for my TV102.
I m also convinced to go double stacking, thanks to the double limb topics you have raised. Thanks! f I have been talking to Mark to see if can get me a double stack filter, he will check what he can do, in terms of reflections control, but it seems I will need two ovens/controllers.
Anyone wants to join me in this waggon
Pedro
Posted: Wed Jan 21, 2015 5:37 am
by mdwmark
To get to .2Ang you are really starting below that. They are in the .1Ang range. The focal ratio should be up in the F/50- F/60 range. Unless you are doing Doppler work I don't see any reason to be that narrow. That is why I changed to .3Ang specs. At these narrow HW filters the substrates need to better then 100th wave. It becomes a matter of how nature made the mica and the type of mirrors you have on the substrate.
Unlike an air spaced etalon you only have one shot at it. You can't go back and re-polish the flats to a better surface.
The .3Ang filters, I try to have them in that range at F/45-F/50 range. But really a .3Ang filter at F/35 still shows good detail.
To get the image size back down you really just need to use a long focal length eyepiece. I have even used a old 130mm telephoto lens backwards as an eyepiece.
The one advantage of the mica etalon is that you can use it as a variable HW filter, just by changing the focal ratio( going faster you need to increase the temperature also because it has shifted blue).
Mark W.
Posted: Wed Jan 21, 2015 6:52 pm
by marktownley
mdwmark wrote:The one advantage of the mica etalon is that you can use it as a variable HW filter, just by changing the focal ratio( going faster you need to increase the temperature also because it has shifted blue).
I'd not thought of it like this before... You have my tinkering mind working in overtime
Thanks Mark.
Posted: Sun Feb 08, 2015 8:20 pm
by Bob Yoesle
Christian has updated his analysis with a good treatment of air-spaced etalons, and illustrates some practical applications:
http://www.astrosurf.com/viladrich/astr ... P-Coro.htm
Fantastic information - should be added to the Library I should think (hint Mark
Posted: Tue Feb 10, 2015 4:45 am
by swisswalter
Thank you Bob
Posted: Sun Mar 29, 2015 9:02 pm
by Bob Yoesle
Christian continues to update his analysis of filter performance. Here's his latest, which gets to a question Ken had raised about how blocking filters affect bandpass, as well as mixing different primary FWHM's:
http://www.astrosurf.com/viladrich/astr ... ntrast.htm
Posted: Sun Mar 29, 2015 9:19 pm
by marktownley
Another great read from Christian!
Posted: Mon Mar 30, 2015 4:09 am
by swisswalter
Hi Bob
thank you very much, most interesting
Posted: Fri Apr 10, 2015 8:27 pm
by Bob Yoesle
Christian just let me know he's added an update to the above Blocking Filter analysis - very interesting results using an DayStar 0.6 A with an Omega 4.5 A used as a BF...
Posted: Fri Apr 10, 2015 9:24 pm
by marktownley
An interesting addition. I believe this is the principal of how I get the contrast gains that I do with my quark and naked PST etalon.
Posted: Sat Apr 11, 2015 12:14 am
by Valery
One more excellent addition to Christian's book.
