ITF rusty on a Coronado BF15
jacquesfrr
Post by jacquesfrr » Tue Apr 14, 2015 1:50 pm
Hello,
My ITF filter is oxidizing at the periphery :
http://www.webastro.net/upload/images/7 ... 016792.jpg
I have read that the Maier ITF is a good replacement.
How Is the view through a Maier ITF ? Some say the view is less good, some say better than the Coronado ITF, so I don't know ?
Thank you
Jacques
Re: ITF rusty on a Coronado BF15
Post by marktownley » Tue Apr 14, 2015 7:03 pm
Hi Jacques,
Yes, that is definitely oxidizing. I have the Maier on a BF15 and it works just fine :)
jacquesfrr
Post by jacquesfrr » Tue Apr 14, 2015 8:45 pm
Thank you Mark,
Do you use your BF15 on a Solarmax filter ? In visual mode, would you say the Maier is better than the Coronado ITF ?
04Stefan07
Post by 04Stefan07 » Tue Apr 14, 2015 9:37 pm
How come the filters start to oxidize over time?
Is it a design flaw or that's just the way it is?
SOLAR SCOPE: Lunt LS50THa Pressure Tuned including B600 filter
MOUNTS: Skywatcher HEQ5 Pro & Skywatcher Star Adventurer
CAMERA: Flea3 1.3 MP Mono USB3 Vision (VITA 1300) & QHY5L-II Mono
Post by swisswalter » Wed Apr 15, 2015 4:55 am
Hi Jacques
for imaging a mod can not do much harm. I wouldn't use it for viewing though
Post by marktownley » Wed Apr 15, 2015 5:23 am
jacquesfrr wrote:Thank you Mark,
Visually I can tell no difference, for imaging it lets a little more light through.
Bob Yoesle
Post by Bob Yoesle » Wed Apr 15, 2015 6:30 am
The ITF is susceptible to deterioration from thermal loading and cycling from ERFs that have no IR blocking. To help prevent this you should use an ERF, such as the Lunt or the Baader, that incorporates IR blocking as well a s UV (usually provided by the RG630 glass substrate itself.)
The ITF is a "sandwich" filter that incorporates metallic silver layers, and is sealed around the edge with epoxy. However, thermal loading and cycling can cause small cracks in the epoxy, which will admit atmospheric moisture, and the deterioration begins at the periphery and moves inward over time, as can be seen in the picture.
Additionally, using an IR blocked ERF ahead of the etalon will help with thermal stability of the etalon itself, which will give more uniform contrast when the filter is initially set up.
