Double stack; Quark + Lunt DS unit
Marcello
Post by Marcello » Tue May 05, 2015 11:01 am
I just tried quickly this combination, with the Lunt DS unit 50mm after the Quark, just keeping in hand the unit and the eyepiece, so it was very quick.
Anyway I verified that I can get the focus, and the view seemed pretty nice. Now I'm going to get adapters, so that everything will be strictly fixed and I can try imaging too.
I could try also the Lunt DS before the Quark, but I wonder if the Lunt DS unit can be put after the optic without damage, I don't know exactly what filters are inside.
The optic is a 127mm, with the ERF filter.
Will update with the results!
Play in the sunshine, we're gonna get over !!
https://www.flickr.com/photos/87718267@ ... 5844277683
Re: Double stack; Quark + Lunt DS unit
Post by swisswalter » Wed May 06, 2015 4:25 am
Hi Marcello
good luck with the mod. I would never use a modded system visually. so be carefull
Marcello
Post by Marcello » Wed May 06, 2015 5:18 am
Thanks Walter,
I agree with you in general, in this case I have the Quark and then the DS in combination, then I feel pretty safe, is it wrong?
Post by swisswalter » Thu May 07, 2015 4:15 am
Hi Marcello
you will have to make sure, that you cut away UV and IR, the etalons alone will not do that
Post by marktownley » Thu May 07, 2015 5:35 am
You should only use the Lunt DS unit after the Quark, not before.
Marcello
Post by Marcello » Thu May 07, 2015 8:10 pm
Thanks Walter and Mike,
I will use that only way, the Lunt DS after the Quark. I don't expect any better the other way around.
In the Quark I guess that the first grey filter before the barlow cuts UV and IR
