Good focal reducers for Quark?
There are a couple of cheap brand focal reducers on the market to use with the Quark, but are there any reducers that will be better in terms of dispersion and spherical abberation that would go well with the Quark and a cmos camera? Also, would a 1.25 inch or 2 inch reducer be better fitted to the Quark?
- grimble_cornet
- Been thanked: 47 times
Re: Good focal reducers for Quark?
This might be of interest: http://solarchat.natca.net/viewtopic.ph ... al+reducer
Mike Garbett
Mike Garbett
There are really no good reducers for Quark. Most of them are just a achromat doublet lenses with their own
sets of aberrations. The worst are field curvature, field astigmatism and spherical aberration.
I noticed that if I focus the system for the center, then field edges are softer and wise versa.
And the slower the telescope you do use with Quark, the better a given reducer works - as expected.
Valery.
Valery.
- Astrograph
- Been thanked: 46 times
As I have told many customers, the cheap reducers are not made for tele-centric beams like the Quarks. The only one I know of is the Baader 0.7x Tele-compressor. These are not cheap (£209) but work. They have 2" threads. Unfortunately they are very hard to get hold of
- Has thanked: 20940 times
- Been thanked: 10587 times
I have and use the Baader Solar Telecompressor. It is great and shows none of the uneven field illumination, curvature and softness towards the edges like the cheapy 0.5x version I first tried. I whole heartedly recommend it.
- Has thanked: 3096 times
- Been thanked: 2198 times
what about this for the Quark? anybody tried the daystar 0,5x / 0,33x reducer with 4 lenses? sounds like a relevation for Quark users..
https://www.astroshop.de/flattener-korr ... r_0_select
Triband C9.25
H-a: 1-2 Lunt40 rear mounted
Ca-K: homebrew (includes 2x 1.5A filters, thanks Apollo), corrective lenses (thanks again Apollo)
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
grimble_cornet wrote: ↑Tue Jul 28, 2015 10:22 pm This might be of interest: http://solarchat.natca.net/viewtopic.ph ... al+reducer
Link does not work please check it when posted thanks
72mm Ed Skywatcher for Solar
SkyTee 2
Sky-Watcher SolarQuest
Gitzo Systematic Series 5
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
the link works fine for me..
here is another one:
https://www.bhphotovideo.com/c/product/ ... 0_33x.html
but can also be found on google: "daystar reducer 0.5x"
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Many thanks
Looks good but a high cost
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
- sulcis2000
- Has thanked: 2 times
- Been thanked: 477 times
Hi Markmarktownley wrote: ↑Wed Jul 29, 2015 5:56 pm I have and use the Baader Solar Telecompressor. It is great and shows none of the uneven field illumination, curvature and softness towards the edges like the cheapy 0.5x version I first tried. I whole heartedly recommend it.
how did you put Baader Solar Telecompressor in Quark Filter?
Can you show us a picture?
Thank you
Ale
Alessandro Bianconi
________________
Celestron C14HD Edge
Celestron C14XLT made in USA
Refractor 228 F8 Truss Tube with D-ERF 110mm
Sharpstar 76PHED
Daystar Quark Chromosphere version
Daystar Quark Calcium H
Starizona Hypestar V4
10 Micron GM2000HPS II Mount
Ioptron CEM120 Mount
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
Basler Aca1920-155um
ZWO ASI462MC
Celestron Skyris618M
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
Hi Ale.
I use a Quark to T2 adapter in place of the usual eyepiece holder https://www.firstlightoptics.com/adapte ... to-t2.html
The Baader solar telecompressor goes onto this.
Then I have a Baader 1.25" click lock holder at the other side of the compressor.
- sulcis2000
i Mark
thank you a lot.
I read that the working distance of the Baader Solar Compressor 0,7X is of 110mm (Distance to the camera sensor)
Do you respect it? So you have to add an adapter (T2 female Female thread to a M48 Male thread) and then the Baader Solar Compressor and then 110mm of back focus...is it right?
Ale
thank you a lot.
Ale
Alessandro Bianconi
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
________________
Sharpstar 76PHED
ZWO ASI2600MC Pro
ZWO ASI2600MM pro
ZWO ASI462MC
Hi Ale,
the 110mm distance given for the 0,7x Baader Telecompressor is not very critical; the working distance between Telecompressor and sensor can differ from 110mm by quite a margin, with good results. Just try it out - that is also, what Baader tells you when you ask them (which I did a while ago).
Unfortunately Baader's website is not as informative and helpful in this point as it could be: They are stating the 110mm as the "ideal" or "correct" distance from reducer to sensor, but they also state that you can get different reduction factors by varying the distance reducer-sensor: A detailed report (unfortunately in German only) can be found here: https://www.baader-planetarium.com/de/b ... -spectrum/ (see the table in the paragraph titled "Die Ergebnisse"); the point is also briefly mentioned on their English website here: https://www.baader-planetarium.com/en/b ... essor-0-4/
What I found even more puzzling is the question how to focus a telescope when I am using a Telecompressor: The Telecompressor is designed for use behind a telecentric lens system. In order to make the light path really telecentric you will (also according to Baader) use the telescope's focuser to put the focus point at a specified distance behind the telecentric system (the exact distance depending on your telecentric system), and having done that, the focuser position should stay fixed. NOW adding to your system a telecompressor WITH A CAMERA SENSOR EXACTLY 110mm BEHIND obviously raises the question where to put another (helical or whatever) focuser - or how else to focus.
The practical approach seems to be a healthy dose of tinkering and trial and error... - or at least I did not get a more precise answer from Baader.
Frank
Frank
I used the setup yesterday Ale for my Ha full disk imagesulcis2000 wrote: ↑Mon Dec 28, 2020 4:30 pm i Mark
thank you a lot.
Ale
Ha-FD-DS-bw by Mark Townley, on Flickr
I found a picture of the setup from earlier in the year.
image by Mark Townley, on Flickr
There is a SCT to T2 adapter at the back of the compressor which will take some optical path (10mm?), then the Baader 1.25" clicklock https://www.firstlightoptics.com/adapte ... hread.html (38mm optical path), I then have some extension tubes on the camera c-mount nose piece (~40mm optical path), and then whatever the standard distance for a flir camera to chip is. So, I guess i'm close to 110mm, maybe less.
I have measured before and I reckon i'm running at about a 0.73x reduction factor, would make sense if i'm under the 110mm quoted distance.
why not use the daystar reducer instead? would be straight forward or not?
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
I actually went away from using the Baader telecompressor in this setup in the end, I was getting soft images towards the edge of the field / disk. I swapped to a cheapo 0.5x reducer on a short spacing to get a full disk in the frame. I prefer the latter method in the setup above now.
- The Sun?
- Has thanked: 4 times
- Been thanked: 2 times
Hi, this may be nonsense but I need to ask.
I have a Baader Alan Gee mk II telecompressor
https://www.baader-planetarium.com/en/a ... t-20).html
Do you think if it works in a Quark setup?
Firat
Firochromis wrote: ↑Tue Jul 12, 2022 8:54 pm Hi, this may be nonsense but I need to ask.
if you can adapt it you can try.. wouldnt have too high hopes though.
Triband C9.25
Barlows:
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Try it and see what the results are like...Firochromis wrote: ↑Tue Jul 12, 2022 8:54 pm Hi, this may be nonsense but I need to ask.
