Cool Baader Wedge
Solar B
Cool Baader Wedge
Post by Solar B » Mon Sep 14, 2015 8:55 pm
Hi Folks
Is the adaptor in the foreground the one that's best suited for fitment
of the ND3 ... and then perhaps the solar con could be installed
to the nose piece ... this would be for visual use ... or what would be
your recommendation.
grimble_cornet
Re: Cool Baader Wedge
Post by grimble_cornet » Mon Sep 14, 2015 9:54 pm
I assume you are using the Baader 2" ceramic wedge?
I bought the 'imaging' version which comes with a selection of 2" ND filters and a 2" Continuum filter.
The ND3 filter MUST be in place for safe visual use.
I stack the ND3 and Continuum filters via the eyepiece holder - threaded adaptor ring as shown here:
I don't see why you would want to put the continuum filter anywhere else unless you want to be able to add/remove it easily during use?
Mike Garbett
Solar B
Post by Solar B » Mon Sep 14, 2015 10:37 pm
Yes the same Mike ... imaging version but is your EP holder/adaptor ring
easily removed as in my image ? ... I'm used to using the AE solarview 2
which has the ND3 preinstalled.
grimble_cornet
Post by grimble_cornet » Tue Sep 15, 2015 12:07 am
Yep, just screws apart as in the photograph although I never change my setup as I find the ND3 plus Continuum gives me great results in scopes ranging from 60mm to 152mm.
Mike Garbett
Solar B
Post by Solar B » Tue Sep 15, 2015 8:02 am
Thanks Mike .... I don't like the fact that the adaptor can be completely removed
as how do you know how much thread is in place without holding the adaptor
from the inside and turning the body of the wedge ?
