ARIES Full size ERF filters for larger telescopes.
Post by Valery » Fri Dec 04, 2015 11:51 am
Dear friends, solar observers and imagers,
I am glad to announce that my company ARIES started to make full size Dielectric Energy Rejection Filters ( DERF) for
larger telescopes with apertures from 7" to 14".
These filters are mainly dual band - for H-a and CaK (and Ca H ). However residual transmission allows to image
in some other spectral ranges ( 490 or 540nm). No additional filtration required if one will use PST Mod-2, Quark
or any another DayStar or Solar Spectrum narrow band filters/etalons. However an additional 2" Baader 35nm can
completely remove even a trace of unwanted heat. Same job can do a Baader CCD blue filter in the case one will
imaging/observe in a CaK.
These filters also have special anti-fungus coating. each filter have two covers for safe storage. Filters mounted on
a scope in the same way as telescope's dust cover - I do mean filters for SCT scopes.
Of course, we can make any size between 7" and 14" if anyone is interested.
Here are the images of the 295mm D-ERF filter. It seats on my C11 installed in a high elevation "observatory" - about
55m above ground level.
The sun spot image is the best image through this filter I was bale to take so far. If I will meet better seeing this winter,
I will surely add more images. It is clickable for a full resolution.
Thanks for looking.
Valery Deryuzhin
ARIES
ERF C11 ARIES 01.jpg (174.78 KiB) Viewed 12979 times
ERF C11 ARIES 03.jpg (179.97 KiB) Viewed 12979 times
Re: ARIES Full size ERF filters for larger telescopes.
Post by marktownley » Fri Dec 04, 2015 10:39 pm
Sexy time!
Do you have a transmission curve?
longtech
Post by longtech » Sat Dec 05, 2015 2:32 am
...or pricing for the 8"?
zorgdotnl
Post by zorgdotnl » Wed Dec 16, 2015 3:09 pm
Do you have the price for a C8?
Post by marktownley » Wed Dec 16, 2015 7:21 pm
Hey Valery, any luck with that transmission curve?
Post by Valery » Thu Dec 17, 2015 4:15 am
marktownley wrote:Hey Valery, any luck with that transmission curve?
Not sure, Mark, what did you mean "luck" here. It does work like it were designed for.
Transmits two main peaks at 394nm and 656nm and attennuate all in between and down to
far IR. It removes about 95% of solar heat between these two peaks and down to far IR.
To make an Ha etalons totally free of any saun heat influence, I do use Baader 35nm or 7nm
H-a 2" filters.
Valery.
Post by marktownley » Thu Dec 17, 2015 6:23 am
Valery wrote:Not sure, Mark, what did you mean "luck" here.
Sorry Valery, it's just a figure of speech I was using - wasn't implying there was any 'luck' with the ERF :movie
Post by Valery » Sun Dec 20, 2015 7:55 pm
I added the best image I was able to take with this set-up so far, under barely so so seeing.
See the starting post. The image is clickable for a full resolution.
Thanks for looking.
Post by MapleRidge » Mon Dec 21, 2015 3:17 am
Hi Valery...
Mark was hoping that you could post the transmission curve for the ERF...'luck' would be a successful posting.
Great image from the C11
Post by Valery » Fri Mar 18, 2016 5:11 am
Hi all,
For those who may be interested.
We now approaching the finish line for few first large D-ERF filters ordered by our solar charters.
And I can tell that occasionally we were able to source some more large BK7 type glass of large size
and wood quality. In such, we do have one 385mm (for C14) two 295mm (for C11) and two 215mm
(for C8) filters in a progress and they are not sold already.
If anyone is interested, contact me via e-mail or PM.
Thanks,
Valery Deryuzhin
ARIES.
Post by Valery » Fri Mar 18, 2016 12:56 pm
One 295mm and one 215mm were preserved.
So, only one filter each mentioned sizes are still available in a short perspective.
Post by Valery » Mon Mar 21, 2016 3:42 am
The last 215mm has been ordered.
One 385mm (for C14) and one 295mm (C11) still remain available for a short lead time.
Valery.
jp-brahic
Post by jp-brahic » Mon Mar 21, 2016 7:25 am
Hi Valery
I 'm impatient to test these new big Aries erf
JP
TN 450mm F/D 4 Zerodur
alexhuangyan
Post by alexhuangyan » Wed Apr 03, 2019 1:18 am
Dear Valery
What is the optical quality of the ERF?
alexhy
Post by Valery » Wed Apr 03, 2019 7:45 pm
Dear Valery
alexhy
Alex,
The wave front distortion is less than 1/8 wave.
Here at the main forum you can see Marty's Wise recent image (from April 3) of the current AR12737. He took his images with his C8 telescope equipped with the ARIES DERF 214mm. See how good is the resolution in the AR.
If you have any questions from me a PM.
MalVeauX
Post by MalVeauX » Wed Apr 03, 2019 9:13 pm
The optical quality is fantastic. :bow
I'm very pleased with mine. Thanks Valery!
