Newton Rings
photon hunter
Newton Rings
Post by photon hunter » Sat Mar 26, 2016 10:14 pm
I have been having trouble with newton's rings when ever I use a Barlow on the following assembly: Lunt 100, double stacked with Solar max 90, with either a DMK-41 or zwo 177 cameras. Any suggestion as to how to correct/eliminate the rings?
Burton
Re: Newton Rings
Post by marktownley » Sun Mar 27, 2016 8:24 am
Tilt the camera or take a flat :)
_Zakalwe
Re: Newton Rings
Post by _Zakalwe » Sun Mar 27, 2016 11:52 am
As Mark says, tilting the camera works well. I use a Rowan Astronomy tilt-adapter with my ASI174 camera and it works very well.
photon hunter
Re: Newton Rings
Post by photon hunter » Sun Mar 27, 2016 11:22 pm
Thanks Mark and Zakalwe. Will try flats first, if no success then the adaptor. When using the adaptor does the tilt throw one side out of focus?
Re: Newton Rings
Post by MapleRidge » Mon Mar 28, 2016 12:06 am
Hi Burton...
The amount of tilt is very slight, so focus should not be affected.
grimble_cornet
Re: Newton Rings
Post by grimble_cornet » Mon Mar 28, 2016 1:34 pm
I used to use a DMK41 on my LS100 (and several other scopes) and found that a 'clingfilm flat' solved the problem (search the forum for instructions) unless I was using a TV x2.5 Powermate which seems to be very prone to NR. The tilt method will also work (I made my own unit and have also used a commercial one) BUT....... with early ZWO camera the tilt required was so extreme that I had to fit longer screws to the unit and yes, the focus was effected!
Mike Garbett
Re: Newton Rings
Post by marktownley » Mon Mar 28, 2016 2:34 pm
Cool design Mike!
Derek Klepp
Re: Newton Rings
Post by Derek Klepp » Mon Mar 28, 2016 8:21 pm
Good luck .I find at high mag I see some rings but the flat method usually works well.But I take a defocused flat straight away
EmilN
Re: Newton Rings
Post by EmilN » Thu Mar 31, 2016 8:41 am
Hi guys. I am new here so please help me with the terminology. I recently purchased PG Chameleon with IMX264 and I see a lot of NR. I am familiar with the tilt method but what is "flat"?
robert
Re: Newton Rings
Post by robert » Fri Apr 01, 2016 8:41 am
Try searching the forum, there are several threads on flats, bag flats etc. Mark Townley and Alexandra Hart (Montana) have plenty to say about flats.
Robert
2018 images https://www.flickr.com/photos/69734017@ ... 1234171714
