Lunt LS152 Calcium module - worth a try?
Calavera
Post by Calavera » Fri Apr 22, 2016 5:38 am
Hi together,
what do you think about the LS152 calcium module (which comes combined with a crayford focuser)?
Is it still worth a try? or do I better go with a calcium quark these days?
And do you know how big the Cak Blockfilter is in that thing? I can´t find anything about it in the net... is it a standard size or chooseable - and if how could I find out if buying a used one - there is nothing written on the module.
I just tried a Lunt 60 calcium scope with B600 - which I didn´t liked much so I sold it... (very uncomfortable to watch). Would the LS152 be a better choice?
Thanks! and cs
Chris
"Keep it square!"
Re: Lunt LS152 Calcium module - worth a try?
Post by Montana » Fri Apr 22, 2016 7:04 am
What do you mean by 'uncomfortable'? you couldn't see anything or the eyepiece wasn't right?
How old are you?
If the answer was 'I couldn't see anything' and 'I am over 50 years' then perhaps CaK is not for you in any shape or form ;) perhaps a camera would be better :)
Calavera
Post by Calavera » Fri Apr 22, 2016 5:21 pm
Hi Alexandra,
:) - no I´m not 50 - not just 40... but maybe close ;) and I could see the CaK details - but the contrast wasn´t very good. Uncomfortable was, that I felt it was needed to look directly on the optical axis - a bit aside and details start to disapear I could´t describe it very well - was a bit like black beans (blackouts) with critical kind of eyepieces... I thought the B600 was the reason for that but I´m not sure...
Chris
"Keep it square!"
Derek Klepp
Post by Derek Klepp » Sat Apr 23, 2016 5:18 am
Chris CaK is much more satisfying via a live view or imaging.And you will have difficulties with the eyepiece as the exit pupil is so small with all that light.Have a look at Pedros set ups he does exceptional CaK with the big Lunt scope.
Post by Carbon60 » Sat Apr 23, 2016 5:25 pm
I've just bought a Lunt B600 CaK module and 72mm f6 scope. The combo works perfectly well for imaging. Still tweaking to maximise performance, but I'm very pleased with how it's going.
Lunt LS60THa B1200 PTFT
DMK41, Basler acA1920-155
NEQ6 Pro-mount
Post by Valery » Sun Apr 24, 2016 1:41 am
In my opinion, you don't need a calcium module larger than B1800.
This is absolutely enough for a telescope 80 - 127mm F/9-10 for visual observing and for a full disk images.
And this is absolutely enough for any telescope for a close up high resolution imaging.
And this is too pessimistic scenario. May be B1200 will be enough too, but the difference in price is small
and so, B1800 CaK is a good choice for most cases.
Post by marktownley » Sun Apr 24, 2016 6:47 am
Hi Chris, the Lunt 152 CaK module is basically a 'normal' CaK module on the end of a solar wedge to keep the thermal load off the filters at the larger aperture.
Looking through a B600 will be like looking through a drinking straw, basically it vignettes the eyepiece used to having a 6mm field stop. Eyepieces are transmission dependent on the coatings used, some work, some don't down in the blue end of the spectrum.
The CaH quark is quite different to the Lunt CaK in the sense it is very easy visually to see an image, it offers a clear aperture (field stop) of 21mm so you are unlikely to get vignetting with most eyepieces. It has slightly less contrast than a Lunt CaK, but for imaging offers fast exposure times. Given it's cost too I would seriously consider giving one a try.
solarchat
Site Admin
Site Admin
Post by solarchat » Sun Apr 24, 2016 12:36 pm
one more note if it matters to you…
Lunt Solar Systems has been the biggest sponsor of our solar outreach program, this forum, solarastronomy.org and everything we do here to spread the hobby since the first day we started.
Daystar has never offered or done anything to help our program, which played a large role in making their quark the success it is through this forum and it’s members.
Make your choice wisely.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
