pressure tuner issue
DSobserver
Post by DSobserver » Fri Aug 05, 2016 10:19 pm
hi friends
I've tried this week a lunt152 scope from a friend.
Nice pictures but they were an issue : it was loosing pressure within few seconds!
we unscrew, screw, unscrew...everytime the same issue!
have you ever face this?
Cometeer
Re: pressure tuner issue
Post by Cometeer » Sat Aug 06, 2016 6:30 am
This is a somewhat common problem with pressure tuners. See this thread. Usually the case is that the tuning system requires more grease on the threads or the o-rings need to be replaced. Call Lunt, they'll send you the replacement o-ring and grease. My club replaces the o-rings every few years on their LS100 because they deteriorate eventually.
In rare cases it might be a leak somewhere on the pressure component inside the scope. When replacing the o-rings and regreasing didn't fix the problem with my brand new scope, I sent it to Lunt. They replaced my scope and the new one is leak free. Before sending them the scope though, try replacing the o-rings first.
Post by marktownley » Sat Aug 06, 2016 8:34 am
Easy fix. I've mended a few like this.
At the end of the pressure tuner vessel unscrew the black facing cap. When this is removed you will see an Allen bolt, this sits on a rubber gasket. Tighten the bolt and the leak will stop.
Let us know how you get on.
