Help! Imaging Source & laptop issues
mattwastell
Post by mattwastell » Wed Nov 16, 2016 9:01 am
Hi all
I hope someone can help.
I am trying to install the drivers & capture software to my new computer (MS Surface).
It appears to download fine but I keep getting this message
I have tried everything but without success - I have downloaded this many times without issue on other computers - I am stuck.
Thanks in advance.
Matt Wastell
Look up, look good!
http://www.pbase.com/mattwastell
GUS
Re: Help! Imaging Source & laptop issues
Post by GUS » Wed Nov 16, 2016 10:09 am
You can still use your camera, but you will have to set the frame rate to half to see an image. This is a known issue when using imaging source USB2 cameras on newer laptops with USB3 ports and Intel chipsets, for more info have a look at the Imaging source forums.
mattwastell
Post by mattwastell » Wed Nov 16, 2016 10:11 am
Thanks Gus - I will have another play tomorrow & look at the forums.
GUS wrote:You can still use your camera, but you will have to set the frame rate to half to see an image. This is a known issue when using imaging source USB2 cameras on newer laptops with USB3 ports and Intel chipsets, for more info have a look at the Imaging source forums.
Matt Wastell
Look up, look good!
mattwastell
Post by mattwastell » Thu Nov 17, 2016 8:15 am
All sorted - will be at half speed - hope to get a run over the weekend to see the real impact.
Matt Wastell
Look up, look good!
Post by Montana » Thu Nov 17, 2016 3:28 pm
I don't think I would settle for half speed, the DMK51 is slow enough! Imaging source must have a fix?
mattwastell
Post by mattwastell » Fri Nov 18, 2016 7:28 am
I will keep looking through the forums - I have not found out too much except for some technical mumbo jumbo that is like double Dutch to me. I was happy to at least see the computer & the camera talking! I will have a run over the weekend & see what happens. I have been toying with a new camera anyway :D
Montana wrote:I don't think I would settle for half speed, the DMK51 is slow enough! Imaging source must have a fix?
Matt Wastell
Look up, look good!
Post by Merlin66 » Fri Nov 18, 2016 9:24 pm
Alexandra, et al,
I raised this issue - seems to affect only the DMK51 (?!) on the TIS group.....
No additional reply - only that the camera will operate at half frame rate on USB3.
They don't seem to be interested in solving the problem.
Users browsing this forum: fbarraza28 and 1 guest
