Autofocusing coming to Genika
fjabet
Post by fjabet » Sun Dec 11, 2016 11:58 am
Hello all,
I've been working on a real planetary/moon/solar autofocus implementation for a while, and here is the first fully automated run in video.
It's done on the 203mm HaT, there couldn't have been worst condition : dust on the sensor, bad bad seeing, low featureless sun...
But it works !
The graphic shows the focus score on the different focuser steps, and then the gaussian fit.
Re: Autofocusing coming to Genika
Post by marktownley » Mon Dec 12, 2016 11:31 am
Very interesting indeed Frederic! We're you focusing the HaT manually here?
Post by Montana » Mon Dec 12, 2016 12:13 pm
Yes, that is my question too, I only have manual.
PDB
Post by PDB » Tue Dec 13, 2016 10:16 am
Would be nice if I got normal focussing to work.
Jog window is not even working with my Ascom focusser.
Works without problems from the ASCOM box and from FireCapture.
Genika has too much bugs for me.
Paul
fjabet
Post by fjabet » Tue Dec 13, 2016 10:13 pm
@Alexandra and Mark : the new focus score is also present in the manual focusing, along with a new slopes display (image derivate). This release should be online by the end of this week.
@Paul : I know I had a few awful issues with the 2.12 release due to several changes (Visual studio 2010 to 2015 that brought a lot of issues). And it took me some releases to find them all. But the current live version solves all the issues detected before. What focuser are you using ?
Don't hesitate to contact me, it is very difficult to check all the configurations and sometimes a Teamviewer session can allow me to find a bug that won't occur on my PCs. For example a huge issue that affected few PC was due to the function I used to get the free memory which wasn't present all the time. And it blocked some initialization of other processes just because of that.
Frédéric.
PDB
Post by PDB » Wed Dec 14, 2016 7:49 am
Hello Frederic,
will send you a list with all the problems i still have with Genika 2.12, but first need to test it on both my PC's. (This will take a while because I want to run the tests in different setups to see if there is an interaction with other software or setups I am using) BTW the focusser is a Rigelsys nFocus. Their Ascom implementation does not seem to be very rigid, so some problem might be in that interface. I tested yesterday with the Myfocusser implementation on an Arduino (seems to work like Moonlite) and that connected without problems.
Paul
fjabet
Post by fjabet » Wed Dec 14, 2016 8:20 am
Maybe an issue is that Genika requires an absolute focuser. If the focuser is a PWM focuser (pulse wide modulation) then it is a relative one.
rbenton
Post by rbenton » Thu Dec 15, 2016 12:56 am
This looks great. What sort of focuser is required to take advantage of this feature?
Randall Benton
fjabet
Post by fjabet » Thu Dec 15, 2016 2:51 pm
Any ASCOM focuser wil do if it is an absolute one, most steppers focusers are.
Here is a link to the user manual, everything is explained there : http://airylab.com/Drivers/EN%20documen ... 202.13.pdf
The new release is online now.
