Grasshopper3 how to ??
Hey guys I have had a Grasshopper3 2.8 MP Mono USB3 Vision for quite a while and never used it, now that I’m retired I want to learn how to use it.
I have been able to connect it up and get a live view image through a small scope on some trees but that’s the limit of my capabilities.
Are there any utube videos on how to use it, I have googled how to sst it up but found nothing of any use.
Any advise would be welcome.
Al
Al
Alan
- GreatAttractor
Re: Grasshopper3 how to ??
You need something like this: Baader C-Mount/1.25" adapter, then you can plop the camera into any telescope. FireCapture should work fine for video acquisition.
My software:
My images
My images
You may have miss read my post I have it all mounted on a solar scope and I can get live view of the sun or anything I point it at when mounted on a normal scope but I don’t know how to set the correct camera settings then take a photo and save it.
Al
Al
Alan
what capture software are you using Alan?
Use firecapture mate, flycapture is awful!
I agree with Mark, you won't get anywhere with Flycapture. You just need to open it once in Flycapture to set the drivers then forget about it.
Ok got FireCapture installed now I’ve got a small issue with the lap top I need to get fixed then I should be up and away.
Al
Al
Alan
