I have a BAADER Herschel CC wedge that is normally used with my TV 85 APO refractor. The specs say it can be used with up to a 8" refractor.
I have an Officina Stellare 152mm 1200mm fl refractor that has TMB air spaced triplet APO optics. I have the appropriate ND filters, etc. with the Herschel wedge but wondering if I should use a ERF and/or UVIR filter on the scope in front?
Herschel Wedge with 152mm 1200 TMB refractor?
- Has thanked: 54 times
- Been thanked: 73 times
Day Star Quark Chromosphere
ASI AIR Plus
ASI AIR Plus
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Re: Herschel Wedge with 152mm 1200 TMB refractor?
I normally use a Baader CC with my 150 mm f/5 refractor without problems. Inside the wedge there are ND3.0 + ND06 filters. Someone adds a UV/IR cut before or after the wedge, I am not sure it is necessary.
- Been thanked: 8906 times
I use my Baader Herschel wedge no problem for hours on my TEC140, no ERFs.
- Has thanked: 20813 times
- Been thanked: 10485 times
You'll be fine.
Thanks all for answers. Now all we need is some solar activity.
ASI AIR Plus
ASI AIR Plus
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
I tried recently a 2" Baader ceramic solarwedge fitted to a APM180 F/6 for about 30min.
Although the windows gets hot it is fine. You can use it with your 152mm refractor
Pedro Re'
