Omni xlt 120mm and quark
Just testing the water to see if anyone has any advice on using the omni xlt 120 refractor with a quark.
What can i expect to see with the views,do i need an external erf.
Am i better off buying a dedicated solarscope.
Thanks in advance
Mick
Thanks in advance
Mick
- Has thanked: 20229 times
- Been thanked: 10111 times
Re: Omni xlt 120mm and quark
At f8.3 I would think it would work very well. By far the weakest link will be the stock focuser.
- PDB
- Has thanked: 2 times
- Been thanked: 149 times
Yep, that stock focuser is a nightmare. The scope is very much ok in H-Alfa.
I have the Skywatcher version and replaced the focuser with a Baader Diamond Steeltrack.
This scope has a very short tube. With the very long stock focuser and a 2" diagonal it will be ok. Wit focuser replacement you will need extension tubes.
I used (before my Quarl died) with the Baader focuser, 2 80 mm extensions to come to focus without diagonal. (Only 1 needed with the 2" diagonal)
Paul
Paul
Thanks for the replies but my questions still arent answered,what views will i get,full disc partial??
Do i need an external erf?
Would i be better off with a dedicated solar scope?.
- PDB
Impossible to get full disc with that scope and standard Quark. The blocking filter only allows full disc view with scopes with fl ~400mm. (I have a 80mm f/6 -> 480mm FL, does not give me full disc either, FL just a tad to long)
An UV/IR (best a 2") in front of the Quark will do. Better a Baader 35nm H-Alfa filter. Blocks more and is cooler that the UV/IR.
My setup was: 2" UV/IR (later replaced with the 35nm H-Alfa); 2w 80mm extension tubes, quark, camera.
For visual: 2" UV/IR (later replaced with the 35nm H-Alfa); 2" diagonal, Quark.
Hope this helps
Paul
Hope this helps
Paul
Exactly what Paul says. Who knows if you will be better buying a dedicated solar scope - what do you want / expect?
Ok thanks for the help,how would the quark perform with a 10" schmidt at 2500mm and a mak 180 at 2700mm,would i need erf,s with these also?
- PDB
For Maks & SCT's you will need a cool front ERF. (Baader, Aries ...) Without it, too much heat will build up in the tube and reflected from primary to secondary mirror. You risc melting (if plastic parts) or secondary coming of (if glued) You can't work with an UV/IT in front of the mirror.
Of course you can use the off-axis erf with a combo quark, but what is the point of turning a big scope into something like a 50 or 60mm scope?
Quality: you will need good seeing, but there are always good moments. Others with the big systems (Valery, Mark, Franco ...) can probably advise on that.
Paul
Paul
With a big scope like your Mak or SCT unless you live somewhere in the UK with spectacular daytime seeing you won't be getting much use. I'd go with the 120 in the first instance.
- daslolo
- Has thanked: 4 times
- Been thanked: 3 times
Does 2" eyepieces help bring details? The quark being 1.25...
What happened to your quark? Daystar fixed it?
These quarks seem fragile...
LX65 8" ACF
LX65 8" ACF
- PDB
The first one: my dealer sent it back to Daystar and they sent me something bach after a few months. (Replaced or new, can't say since they have no serial number. Too costly just to put a serial on it? My dealer took all the cost of sending it back and forth (warranty)
Second one looked ok with good contrast but later started to show strange spots (as if some internal "oil" spil. Probably could get another one, but sending it back to the US and pay import tax again and probably get another lemon. No thanks! Is a nice paper-weight now.
You get what you pay for .... Wel ask Rainer (rsfoto) about his daystar adventure.
Paul
Paul
