Here are the three scopes I use primarily for solar work Two in white light. One an old Traq f11.6 refractor I bought with the money from my first job back in 1982. It is equipped with Baader Astrosolar film filter. My second white light instrument is a dedicated Orion 70mm F7.1 solar telescope with a non removable glass filter. It has largely replaced the older Traq scope. It gives sharper images and is even more portable. The glass filter which has an almost white image does very well with good contrast. I plan to get a Baader Continuum filter to boost contrast even more.
My third scope is a Coronado Solarmax II 60mm Ha refractor. Ever since seeing prominences for the first time through the Traq during totality during the 2017 Solar eclipse did I started thinking seriously about investing into an Ha instrument that would allow me to see them anytime. I really enjoy the Coronado though I wish sometimes it would do high magnification work.
I have a Celestron Nextar 102 refractor that I probably in time will buy a DayStar Quark for. I also plan on getting into solar imaging but for now I am equipped only for visual work.
My Setup
- Has thanked: 17458 times
- Been thanked: 16558 times
My Setup
- Solar Observing!.JPG (6.24 MiB) Viewed 2964 times
- Solar at Dad's.JPG (6.47 MiB) Viewed 2964 times
- Has thanked: 20240 times
- Been thanked: 10113 times
Re: My Setup
Nice setup James, thanks for sharing!
Re: My Setup
It's simple but a start. And a learning experience.
- Has thanked: 173 times
- Been thanked: 615 times
Re: My Setup
Looking good!
The SolarMax DS 60 is a great starting point.
Re: My Setup
I initially bought the single stack scope and added the second etalon a couple months later.
Re: My Setup
Good call!
I had an original Solarmax 60 which came with an external etalon (no Rich view tuning etc.) and added a second external etalon for DS.
Moved the double stack to the ED80 for better performance. I now use an original SM60 etalon mounted on a SME60 II (rich view tuning) DS on the ED80.....
Re: My Setup
So far the Coronado etalons do well. I was skeptical at first seeing that the Coronado etalons have a rather large 20 percent central obstruction. In my experience with nighttime reflectors a large central obstruction means reduced contrast. A central obstruction of any kind is odd in a refractor.
Very nice setup! It seems the Coronado etalons do well with other scopes too!
