Herschel Wedges
Has thanked: 9319 times
Been thanked: 6157 times
Herschel Wedges
Post by ffellah »
Hello all: I am contemplating buying a Herschel Wedge for my 152mm refractor. I am looking for feedback/experiences with various types of wedges, and particularly the more reasonably priced Meade and Lunt 2" models ($300 range here in the US). i am not sure I am prepared at this point to shell out the $600 to $750 for the Baader models. Also appreciate knowing the configuration of the systems used (barlows, powermates, camera used). This is for granulation images.
Thank you in advance for your input.
rsfoto
Has thanked: 9723 times
Been thanked: 5773 times
Re: Herschel Wedges
Post by rsfoto »
ffellah wrote: Fri Dec 27, 2019 4:55 pm Hello all: I am contemplating buying a Herschel Wedge for my 152mm refractor. I am looking for feedback/experiences with various types of wedges, and particularly the more reasonably priced Meade and Lunt 2" models ($300 range here in the US). i am not sure I am prepared at this point to shell out the $600 to $750 for the Baader models. Also appreciate knowing the configuration of the systems used (barlows, powermates, camera used). This is for granulation images.
Hi Franco,
I once had one Lunt 2" but sold it at is was redundant. You need some ND filters and a continuum filter ( green filter ) to enhance contrast.
Check what is included in the Lunt package. So far It has only a ND3 installed grey filter, no Continuum filter ...
Baader has a P version = Photographic and a V version = Visual ... and the photographic version has included a set of green filter and 3 ND filters ...
Baader looks interesting. Honestly I do not know why the Badder are so expensive ? Made in Germany does not justify that price ... ?
Perhaps others have more information about why Baader Herschel wedge instead of Lunt Herschel wedge ¿?
The back part gets a bit warm but that is all. The backfocus distance is the same as if you use a 2" diagonal.
Has thanked: 17974 times
Been thanked: 8906 times
Re: Herschel Wedges
I have the Baader photographic version. It is absolutely superb and comes with many different combinations of filters to you can mix and match to suit your camera and powermate. All the filters and continuum filters come in the set. This is probably the added expense, it also comes in a lovely carry case too.
A long time ago the Lunt had a fixed ND5 filter so it wasn't easy to use for photographic but as usual I think Mark T managed to break it open and swap the ND filter. I am not sure if this has changed now or not.
Re: Herschel Wedges
Post by ffellah »
Thank you Rainer, Marcus and Alexandra for your input.
Rusted
Has thanked: 8172 times
Been thanked: 1943 times
Re: Herschel Wedges
Post by Rusted »
I have the Lacerta 2" with the odd Brewster angle.
It appears to be optically fine and the heat sink remains cool in my 7" f/12.
It has a rotatable top stage which allows very easy dimming using a single polariser.
It has a built in ND and I added a 1.25" Baader Solar Continuum.
The third filter actually exceeds the stack capacity of the standard 1.25" eyepiece holder.
Requiring some care on insertion of accessories. The Lacerta is heavy and robust when carrying binoviewers.
The 67°exit angle, rather than the more normal 90 may be at a disadvantage in some situations.
Particularly if you live in the Southern Latitudes and want to use it visually at high noon with binoviewers.
Though it is fine at all other times of morning and evening, almost everywhere, when the "seeing" may be better.
However, if you want to use a camera with the Lacerta prism.
Then it won't complain of an aching neck from staring predominantly upwards, around lunch time, in high summer. ;)
P1370278 rsz.JPG (195.14 KiB) Viewed 5284 times
Re: Herschel Wedges
Post by ffellah »
Hello Rusted: thank you very much for your input. After reading your post I looked around the web and the Lacerta seems to be a very interesting and intriguing design. It also seems like a number of members of this forum use it very successfully. I will do more homework on this but certainly seems worth of consideration. Thanks again !
Has thanked: 8559 times
Been thanked: 8290 times
Re: Herschel Wedges
Hi Franco,
I’ve responded to your PM.
Re: Herschel Wedges
Hi Franco,
My PM seems to have gone adrift somewhere in hyperspace.
Basically, yes, I can recommend the Lacerta. I added a continuum filter, removed the supplied ND filter and use one or two polarisers to adjust the brightness to max out the shutter speed at a few microseconds to steady the effects of poor seeing.
Hope this helps.
Re: Herschel Wedges
Post by ffellah »
Very helpful, Stu, thank you !
rsfoto
Re: Herschel Wedges
Post by rsfoto »
Has thanked: 17853 times
Been thanked: 16996 times
Re: Herschel Wedges
Post by DeepSolar64 »
Franco,
I am considering getting a Lunt wedge myself.
