Lunt LS100Tha Double Stack
Has thanked: 1300 times
Been thanked: 1369 times
Post by DeepSolar64 » Tue Apr 28, 2020 5:18 am
All,
Does anyone here have any experience with a double stacked Lunt LS100Tha scope? I am strongly considering buying one of these in the near future. The SolarMax II 60 I already have would still be a full disc grab and go but I would like to have an instrument that would give higher magnification and finer detail than I can get with the Coronado 60, and hopefully a more consistent tuned field and better contrast. If I dive in deep I may even get a CMOS video camera to go with it and go beyond visual. Do you think this scope is a good choice or would the LS80Tha DS be a better choice? Or a Coronado SolarMax II or III 90 DS?
https://luntsolarsystems.com/shop/solar ... ouch-zoom/
Has thanked: 2224 times
Been thanked: 862 times
Re: Lunt LS100Tha Double Stack
Post by marktownley » Tue Apr 28, 2020 6:16 am
Yes, have used a few. One was my friend in Switzerland and it provided stunning views, the other was a pal who live close by here and the views were awful. Bit of a mixed bag from my perspective then. What I always say to anyone considering an outlay like this is to either try before you buy, or, even better buy from somewhere that has an extended returns policy. I still have no faith in any of the main solar companies to provide consistent quality controlled products. (but then i'm a perfectionist with my solar gear!)
Post by DeepSolar64 » Tue Apr 28, 2020 6:51 pm
Mark,
I understand that. Judging by what I have read though, Lunt seems better on average in quality and service than does DayStar and Meade Coronado. Now on Solarscope I have no idea.
I have always had doubts about my Coronado 60. It seems to me not contrasty enough and has a very defined sweet spot. It might be just me. I have nothing to compare it to.
Post by marktownley » Tue Apr 28, 2020 6:53 pm
Have you got 2 external etalons or is one internal in the scope James?
Post by DeepSolar64 » Tue Apr 28, 2020 8:52 pm
My Coronado 60 has one internal etalon and one external etalon.
Has thanked: 2442 times
Been thanked: 839 times
Post by Montana » Wed Apr 29, 2020 7:40 am
I would probably go for the Lunt 80mm double stack, lots of people on here use them and love them. I have never heard much or anything good about the 100mm double stack, does anyone own one? too much risk to me.
Post by marktownley » Wed Apr 29, 2020 7:58 am
How long have you been observing in Ha James?
Post by DeepSolar64 » Wed Apr 29, 2020 3:37 pm
Alexandra,
The Lunt 80 is almost certainly more forgiving of seeing conditions than the 100 is but how does it do at higher magnifications? It's one of my Coronado's shortcomings. I rarely exceed 33x on that scope. 50 usually at best.
Mark,
I am a newbie in the field of H-Alpha. I have had my Coronado 60 since May 13 2019 but have used it almost every sunlit day since. Practice practice practice I say. I may expect too much. Still, I have really enjoyed H-Alpha observing and it adds a new twist to white light as well.
Post by marktownley » Wed Apr 29, 2020 4:20 pm
You are in a fortunate position James. You've experienced solar minimum, but, have importantly cut your teeth and honed your skills on a quiet sun. That means when we do start getting activity it will blow you socks of.
I really liked the Lunt80s when I looked through them which was a couple of three years ago, the combination of Ha detail and also seeing the umbra penumbra of the spots makes for a very interesting disk - don't forget with double stack the sunspots are hidden to some some degree and they are photospheric features, double stack has less parasitic leakage from the photosphere, therefore spots aren't as easy to see.
Once we're up in the 80mm/100mm scope league you're into big bucks, and so are investments not to take lightly, you're definitely doing the right things and not buying on a whim. I don't know what your local seeing is like, you seem pretty rural from the pics (compared to me in the city!) so maybe the 100mm will be a good option. Are you going to keep the DS60 or will this be part of the part-ex if that's the route you take?
You and HighburyMark are both in a similar situation. Make sure patience and reasoning drive what you do rather than impulse, it is the key to long term satisfaction.
Post by DeepSolar64 » Wed Apr 29, 2020 5:12 pm
Mark,
I do live in a fairly rural area. Seeing varies a lot though. For example not so good yesterday but well above average today and it shows in the scopes. I live in a subdivision among apple orchards. Not so far from town though to avoid light pollution from Hendersonville.
I bought pretty blind when I got the Coronado 60 and have second-guessed myself ever since. But again with no solar observers nearby I have nothing to compare it to. You might be able to judge my scope from my observational postings. With scopes it seems you always want more. with nighttime for example it is aperture fever. But I have learned bigger is not always better. The best scope is the one most used and it is usually a smaller grab-and-go instrument. I would keep the Coronado 60 because of this. It would be more portable than an 80 and certainly more portable than a 100. But are they that much difference between a 60 and an 80 in solar observing?
Highbury Mark
Has thanked: 38 times
Been thanked: 54 times
Post by Highbury Mark » Wed Apr 29, 2020 5:49 pm
Good luck with this James. It’s not unusual for SMII60s to lack contrast in my experience, but as Mark says, there’s big variation within the same product line - and that goes for Lunt too, though I’ve always thought they have the edge over Meade/Coronado.
Tak FC-100DC + Quark Chromosphere + Baader wedge
Post by DeepSolar64 » Wed Apr 29, 2020 5:54 pm
Where I hear the difference in Meade Coronado Vs Lunt Solar Systems is in customer support. I have heard from a number of sources including some here that Lunt is much better on this. Service after the Sale matters!!
Rojas522
Has thanked: 9 times
Post by Rojas522 » Thu Apr 30, 2020 4:27 pm
Thanks for posting this. Just like you, I am a visual observer, and I've been thinking about buying this scope for a while after seeing the excellent pictures
viewtopic.php?f=4&t=16532&p=161314&hilit=100Tha#p161314
viewtopic.php?f=4&t=24046&p=216321&hilit=100Tha#p216321
I contacted Lunt Solar last week, and was I learned told that the "old" Lunt 100 is "out of stock" (or discontinued?), you can only get the modular scope. I also called OPT, telescopes.net, etc., with no luck. I have zero interest in the LS100MT.
Frank
Post by DeepSolar64 » Thu Apr 30, 2020 5:15 pm
Frank,
I will check out the modular scope. I am also considering the LS80Tha double stack. It would be generally more usable in the local seeing conditions I have here. I just wonder if it would be enough gain in resolution for the cost against the SM 60 I already have.
Highbury Mark
Post by Highbury Mark » Thu Apr 30, 2020 6:06 pm
I think a really good double stack LS80 would definitely be a decent step up from your current set up James, though a really good 100 would be superb. As you say, you also have the benefits of support from Lunt in Tucson if anything goes wrong. I suppose the other thing to bear in mind is with Lunt moving to an all-modular range, there may be more people selling their dedicated scopes to buy one of the new ones, and you might be able to pick up something pre-owned from the classifieds. That might mean you can afford the 152mm...... :seesaw
Solar B
Has thanked: 22 times
Been thanked: 11 times
Post by Solar B » Thu Apr 30, 2020 8:07 pm
What about the SMIII 90 💙 in DS configuration it's offers the ideal configuration
of 2 externally mounted etalons ! .... It looks amazing to .... I'd love one 🌞
Having owned numerous Lunt 50 and 60s I have not been impressed with any of them plus
I also think that with the new so-called modular systems they're just trying to reinvent themselves.
However it has been often said that the LS80 is the jewel in the crown I've never used one
but they're bandwidth is obviously a little narrower than the 50s & 60s.
Truth be told if money were no object I would opt for solarscope every time they're etalons
offer imho the ultimate in finesse experience.
But the very bottom line is that you won't actually know what you really like yourself until
you have tried and spent some time with the device.
Post by DeepSolar64 » Fri May 01, 2020 7:06 am
Brian,
I am actually considering both the SolarMax II 90 DS and the SolarMax III 90 DS. The SolarMax II can be picked up considerably cheaper than Lunt's offerings or the SolarMax III. But those external etalons are nice and the SM III is probably the most attractive of all the commercially manufactured solar telescopes. And Stephen Ramsden ( SolarChat here ) really endorses the Coronado 90 scopes for visual use.
I also really like the Lunt LS 80. I just wonder if it performs enough above a 60 to justify the cost. A 90 or 100 certainly would.
Post by marktownley » Fri May 01, 2020 8:06 am
Money can't buy the good seeing for it, short of relocating...
Derek Klepp
Been thanked: 170 times
Post by Derek Klepp » Fri May 01, 2020 8:15 am
James I have the Lunt 100 single stack and I love it albeit not as much during the recent Solar minimum.I have a Quark and various combo,s but for pure convenience the Lunt is the best all round. I have dealt with Lunt for various spare parts and they have always come through.I would however take Mark T,s advice and when this crisis has past thouroughly recommend trying before you buy. Don't rush in it is a big investment and there are many alternatives you may even find a good second hand option out there.
Hope this helps Derek
Derek Klepp
Post by Derek Klepp » Fri May 01, 2020 8:17 am
Mark is correct on seeing there. I have a 152mm mod and I was only able to use it 3x in 2years to its advantage due to the seeing.The best scope is the one you use most.
Solar B
Post by Solar B » Fri May 01, 2020 9:15 am
I'm after one myself (80-90mm) albeit on a much smaller budget , I could stretch to an
an SM90II SS but not a III SS ... I think the IIIs look amazing and much better than the LS100
which just looks like a regular scope (which of course it is) plus there are real advantages to an
external etalon configuration 💛
However from my own point of view I must be careful as I don't know if you've heard but there's a
recession coming and there are 5 of us currently at home with 4 cars i,m running so I really
shouldn't be thinking about any scopes at all 😅
Highbury Mark
Post by Highbury Mark » Fri May 01, 2020 10:22 am
LS152 was only a tongue in cheek suggestion. In my city centre location, even a Quark through a 4” refractor is often too much for the seeing.
Worth bearing in mind for James that the LS80 has a relatively modest F/L of 560mm - only 60mm more than the LS60, while both the LS100 and SMIII90 are 800mm - a considerable step up in power as well as aperture. The Coronado’s a hefty beast too - needs strong mount. I have back problems and the 90 would be too much for me.
GUS
Has thanked: 1 time
Been thanked: 2 times
Post by GUS » Fri May 01, 2020 10:28 am
James, I have a Lunt LS100 with the DSII unit.I have had the scope since 2014 and added the DS in 2015. I also own a DS Lunt LS60/60F. The singlestack LS100 provides excellent views and in great seeing I can use up to 200-250x magnification for some real close in prom views. The DSII on the other hand I'm not fond of, It can give some nice views of surface detail, but has quite a noticeable glow which overlaps the suns disk, and prom detail is diminished ( I have rigged up a circular polarizer between the etalons and this has improved the image dramatically) but I personally like the singlestack view better. If I was buying this set up again, I'd buy the SS LS100THa, and wouldn't waste my money on the DSII unit, I'd rather get an SM90 front etalon and get an adaptor plate made up, or if money permits an LS100F front etalon. Another thing is that you can easily get full disk with the LS100 anyway.
Astrograph
Been thanked: 37 times
Post by Astrograph » Fri May 01, 2020 12:03 pm
Just to throw my two pence worth in for some balance and perspective.
I like solar but as a dealer I am not a great lover of the quality / consistency / flexibility vs price of dedicated Solar Telescopes.
As such, while we offer them, I tend to suggest that people consider a rear mounted filter from Solar Spectrum. These are premium filters without any of the associated quality / service issues of Daystar. I happened to have quoted an example of a rear mounted system compared to a Lunt LS100 last night so here it is for comparison;
Lunt 0551401 Lunt LS100THa/B1200 H-alpha solar telescope £6,478.00
Lunt 0551490 Lunt LS100THa/DSII double stack module for LS100THa £2,647.00
Lunt 0551491 Lunt anti-reflection filter for LS100THa/DSII £223.00
Lunt 0554402 Lunt LS150PS Dovetail Bar 150mm GP level £58.00
The above is £9,406.00 in total
As an alternative
Tecnosky 102 F7 (Doublet Super ED Apo) £899.00
Solar Spectrum 25mm 0.5A Etalon £4,299.00
Baader TZ-4 Telecentric £299.00
Baader 35nm H-Alpha Filter £118.00
This is £5615.00. A saving of £3791 over the Lunt. The uniformity of this system will be far superior. I never have worries about that.
The basic optics of this scope are the same as for the LS100 as they come out the same factory. The difference is the Lunt uses ED as opposed to Super ED glass. The SS based system is much longer focal length and a full disc is actually the same size as the etalon so a full disc view is not really possible but the disc is just under 25mm in diameter compared to just over 6mm in the Lunt.
If you were happy to spend the £3800 you had saved, there are options.
The ERF in the SS system is internal. You could use a front D-ERF for even better performance. With a cell that would add £511. Or you could go for a bigger etalon. An extra £2700 gets you a 32mm etalon and then you definitely get a full disc. Or you could just spend an extra £1000 and go to 0.3A for super contrast. You could add a CaK Module and a Wedge.
Although this type of system requires you to put it together and is physically longer, it destroys any off the shelf 100mm Solar Scope and costs a lot less. It should be a no brainer for anyone.
Solar B
Post by Solar B » Fri May 01, 2020 12:08 pm
Marks right thats the only downside to the 90mms is that they are hefty brutes 💀
but owning an SM60DS (I've one to) you'll probably already know that.
At the other end of the scale a Daystar 80mm Solar scout would be highly portable and
offer the required magnification plus almost the same ease of use 👴
