SSM settings
Grakrob778
Oh, I get it now!
Oh, I get it now!
Has thanked: 52 times
Been thanked: 28 times
SSM settings
Post by Grakrob778 »
Hello,
I was wondering if anyone could share what settings they use for Firecapture using the Airylab SSM?
It may be self explanatory but I don't understand it quite yet. I first used mine this past weekend and watched the readings. Should I delay the time to 1 second before triggering or keep at zero? I haven't had the time to play like I want with it so I figured I'd ask here. Thank you
Lunt 80Tha B1800, Lunt Ca2K B1200, Solar Spectrum RG18 0.3A, Skywatcher EvoStar 150, ASI 1600MM & 174MM
PDB
Has thanked: 2 times
Been thanked: 149 times
Re: SSM settings
Post by PDB »
suppose you are using the plugin from Joachim Stehle. Have been using that for a while but have never used the delay. Good seeing is scarse so I always tried to keep as much good frames as possible.
I created my own monitor and plugin which is also free to use (https://github.com/paul-db/SolarMonitor/releases) It will work on Windows, Linux and Mac.
I usually balance capturing between two values. Al trigger value (in good seeing set around resolving limit of the scope) and a treshold a bit higher. Then I record everything in between those 2 values. (Setting number of frames to capture not to highn because solar events change quickly)
Paul
Grakrob778
Oh, I get it now!
Oh, I get it now!
Re: SSM settings
Thank you Paul. I will go that route. I will check into your plugin as well. Many thanks. Graham
