I have at last found time to test my Daystar Scout 60 and its not good. Because the image is so dark I have been using my ZWO camera which is working just fine on my other solar telescope. What I am seeing is a double image at the bottom and I can't see a surface detail or prominences. I get the same result with and without a finder any suggestions?
Daystar Scout 60 Image Problem
- Has thanked: 20229 times
- Been thanked: 10111 times
Re: Daystar Scout 60 Image Problem
Hi Lillian
Welcome to the forum! I'm afraid that's decontacted. It needs to go back. No self fixing i'm afraid.
- Has thanked: 22 times
- Been thanked: 11 times
I didn't or hadn't realised that a solid etalon could de-contact
It's obviously always a risk with the much more fragile air spaced etalons
A solid etalon doesn't de-contact. That is something else.
Mark W.
Mark W.
What is it? I had the same with a Mg Quark.
