I'm not sure if this is the right section, so moderators feel free to delete or move to the appropriate section.
Here is a method I used for Collimating my GSO 6" Ritchey Chretien. I don't know if anyone else uses this method.
I would suggest that you familiarise yourself with the Instructions that came with your Ritchey Chretien optical tube
before using this method.
You will need the following to use this method.
1. Barrel type astronomy camera such as a Rising Tech 224 or ASI mini camera with a C mount connection.
2. C type TV lens. An adjustable aperture is essential for getting the correct depth of field.
3. A bright source of diffused light.
4. A PC with Sharpcap or similar imaging software
5. Allen keys
Now you are ready to Collimate your optical tube.
1. Assemble the camera and lens as shown in the picture.
2. Insert the Camera and lens assembly into the focuser, use 75mm of spacers in front of the focuser.
3. Point the optical tube towards a bright diffused light source. This will illuminate the inside of the opical tube.
4. Open your imaging software and adjust exposure settings,then set focus and aperture on the small camera lens
to get an image similar to this, adjusting the f ratio will give you the correct depth of field.
You will need to remove your camera a few times from the focuser during collimation to to adjust your image to optimum settings.
5. Start with your secondary mirror cell. There should be a small doughnut shaped ring
on the center of the secondary mirror, make sure that you can see this with your camera.
Once you are confident that this is visible, center the doughnut within the reflection as per your instructions.
The secondary mirror is now collimated.
6. Now move on to the primary mirror. Adjust your image to show a thin ring on the outside edge of your image.
This ring should be concentric if not adjust your primary mirror as per your instructions.
Once you can see a thin even ring your primary mirror is collimated. The outer ring on my image is dark on one side due
to poor illumination as I used a small desk lamp and a sheet of paper.
[/attachment]
7. Your optical tube is now bench collimated and ready for a star test and final adjustment.
My star test was perfect so no further adjustments were needed.
Martin
Benchtop Ritchey Chretien Collimating with an astronomy imaging camera.
- Martin_S
- Has thanked: 975 times
- Been thanked: 2988 times
H alpha : ,Skywatcher 100mm F10 open frame refractor, a tilted 2" 7nm H-alpha filter as a sub energy rejection filter, Baader TZ4 telecentric focal extender, Player One energy rejection filter, Combo Quark Chromosphere, Naked PST etalon for double stacking, ASI74mm camera
- Has thanked: 20240 times
- Been thanked: 10116 times
Re: Benchtop Ritchey Chretien Collimating with an astronomy imaging camera.
Very informative! Will this work with an SCT too?
- Has thanked: 9243 times
- Been thanked: 5504 times
Hi Martin,
Very interesting and thank you. Will try to do it on my 8" RC from Astrotech.
- Martin_S
Interesting question Mark,It would work on a Classic Cassegrain as they have fixed optics. The SCT optical system is a lot more complex. I'd be more inclined to use an artificial star and a camera with a basic SCT as there are to many variables in the optical train.
Martin
Martin
- Has thanked: 17526 times
- Been thanked: 8763 times
This should be in the Library section Martin
Mark, I don't think it is possible to align the primary mirror on my SCT I think it is fixed, I have only ever done the secondary mirror. Mine also has no dot reference point either, so again this method will not help. The only way collimation can be done is at night with an out of focus star, I use my 3x barlow + camera. Although my Televue powermate in WL on the Sun was pretty good alternative the problem then comes in the fact that the collimation screws are under the Baader solar film
- Has thanked: 173 times
- Been thanked: 615 times
Well done Martin!
Looks like you have a great white light set-up.
Just a note. Al's collimating tool (http://www.iceinspace.com.au/forum/show ... ool&page=2) is a very good tool to assist in collimating.
- Been thanked: 2704 times
Excellent idea. Well done !
- Martin_S
Thanks Ken , I will give this a try.Merlin66 wrote: ↑Tue Jun 02, 2020 11:27 pm Well done Martin!
Martin
- Has thanked: 8355 times
- Been thanked: 8103 times
Ingenious, Martin.
I use a Takahashi collimating scope and my eyeball, but of course I can’t be at both ends of the scope at the same time to look through the scope and adjust the secondary. It would be so much more convenient to use a computer screen to relay the image. This is an excellent solution.
- Astrograph
- Been thanked: 46 times
Just a note for people trying to use this collimation method on similar scopes.
The GSO RC6 is the simplest version and has limited collimation adjustment. To collimate a Cassegrain format telescope the basic steps are actually as follows;
Step 1 - The first thing you must do is collimate the image train. On the 8" GSO RC and larger, there is a collimation flange that the focuser is mounted to. You must first align this to the centre spot on the secondary. Traditionally this is done using a Glatter or Farpoint Laser. Using Martins method I guess you would use a cross hair overlay and centre this on the spot. However that very much depends if the chipset is actually centred in the camera body which is not always the case.
Step 2 - Once the image train is centred now you align the secondary back on the laser or camera as Martin describes.
Step 3 - The next step is to adjust the primary. You can do it as explained by Martin but traditionally it is done on a star so the shadow of the secondary is concentric. This is where Al's collimation aid is useful.
A classic cassegrain and RC are done in exactly the same way but for perfect collimation you need the focuser on a seperate tilt plate. The early GSO RC's (and the RC6) have a problem in that adjusting the primary also moves the focuser so you end up decollimating the image train when you adjust the primary. Therefore you have to try and do it back to front.
An SCT is different. It has no spot on the secondary to start with. The normal tool for this is a Hotech Advanced collimator. This is quite difficult to use as it must be perfectly centred to the scope and the scope and it must be on a floor which does not move when you step on it. Hotech have two online videos about collimating an SCT
With a Meade or Celestron 'C' you can only adjust the secondary. If you add a tilt adjuster on the back you can then adjust the image train. For the Edge range you can also centre the corrector plate.
Really with an SCT, point it at a star and collimate it. There is a limit to how good it can get as the primary mirror flops all over the place anyway and focusing using the primary will shift collimation significantly.
