As suggested by a number of members of the forum, today I invested 3.5 hours to test almost all the settings of the adjustment knob of my Daystar quark.
All the images were obtained by stacking 25% of the best shots in a 1k frame .ser file; exposure 10 ms, focus unchanged, took a flat field for each individual setting placing cellophane on the scope aperture. Minimal post processing, identical for all the shots.
After each click adjustment I let the unit to stabilize (solid green light).
Sky transparency was very good, seeing conditions were changing between the pictures.
The results of the assessment are summarized in the pdf file, in the same order of the experiment (from full CW to full CCW) the pictures are taken 20 min apart.
Since I find it difficult to identify "on-band operation", could you help me by giving your advice/opinion on them?
My particular unit seems to be completely off-band in the CW extremity of the adjustment range: images taken at +5 and +4 CW were total rubbish, therefore were discarded.
On my unit the useful range seems to be between -3CCW and -5CCW.
At -5CCW some bright spots start to appear: if those are EB, then at that setting it should be slightly off-band in the blue wing, but I cannot confirm it since there is no -6CCW setting (As Alexandra said
Also, another conclusion is that the etalon units used in the SS60 have a broader bandwidth than those sold as standalone Quarks.
Cheers
Fabio
