Readily Available Long Focal Length Refractors
- Has thanked: 17458 times
- Been thanked: 16559 times
Re: Readily Available Long Focal Length Refractors
It should work really well, seeing permitting.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Mark,
based on my experience - and yours, I understand - a long refractor with an aperture stop will always be better than a refractor with the same focal length and just that aperture. Stopping down means that only the best corrected part of the glass is working and one can also change the stop diameter to match the seeing. For me this is the way as already suggested by Marty.
As pointed out by Bob a newtonian would be a fine alternative, I have made one myself and in spite is a f/5 it works very well. Skywatcher produces a 150 mm f/8 with parabolic mirror and a modest obstruction that is sold by TS for less than 250 euro. Take this one, de-aluminize the primary, replace the closed tube with a truss structure and you'll have a fantastic solar scope for WL and CaK. You would only need a 2x amplifier to get f/16.
Raf
My Criterion 6"F8 reflector works wonderfully on the planets and moon. WL solar would also be outstanding, seeing permitting.
- Been thanked: 4302 times
The iStar OTA is big but I'll bet the views are amazing! My 6"f8 version is big enough...I don't think that scope would fit in the dome
My bad, I forgot that it hadn't been out of the box!
