DIY: SolarMax 60 Etalon Adapter Plate
kornfeld1
Post by kornfeld1 »
I recently picked up a SolarMax 60mm etalon, and needed an adapter plate to mount it on my 80 mm telescope. The first two options were to buy new, or buy used. All of the new adapaters I saw were in the $125-$200+ price range, which, IMHO, is absurd. I looked around at prices from old classifieds sales to see if they were any cheaper used, and they were still in the $75-$100 range, which is more palatable...but who wants to sit around and wait for a used adapter to pop up when you have a nice shiny etalon sitting at home dying to be put into action? :)
The next idea was to try a local machine shop. I explained what I needed, they seemed to totally understand...and then they came back with a quote for $450. No thank you.
So the last resort was to just build one. I found one thread online showing how someone made their own, but I couldn't find a threaded ring I would feel comfortable just gluing in place...and I like building things and thinking through problems, so I built my own:
Here's how I did it!
First, you'll need to buy a 77mm->62mm step down ring. These are available online on amazon and ebay, or at local camera shops. They're much cheaper online; but I didn't want to wait, and I figured I'd support a local business, so I bought mine from a camera shop. It was ~$10.
Everything else I bought came from McMaster Carr, which is without question one of the coolest companies around. They have just about anything you could possibly need to build something from scratch.
Shopping list:
-One push-on round aluminum cap with a 4.5" inner diameter (scroll down for it; steel would be cheaper, but I was worried about it being too heavy)
-One pack of extra strong, 1/4-20, glass filled nylon thumb screws, 1.5 inch long (scroll down for it; the specific size and pitch of these screws isn't terribly critical)
-One pack of low-head metric socket screws, M3 size, 16mm length (scroll down for them; the size of these screws is important...if they aren't this small, then they will potentially hang out into the light path, or keep the etalon from screwing into place)
-One pack of M3 nylon insert lock nuts, M3 size
-One pack of nylon washers, M3 in size (these probably aren't critical, but I was hoping to minimize the chances of galvanic corrosion between the stainless steel screws and the aluminum cap...again, probably not a huge issue, but I figured I'd do it while I was in there.)
All of that came out to a little over $30.
Tools:
-A jig saw with a small blade for cutting tight circles
-A drill and a set of drill bits
-A 1/4-20 tap (this is for the nylon screws; if you want to use a different tap, just buy a different set of nylon screws)
-A small allen head and a small socket to tighten the nuts and bolts down (I don't remember off the top of my head what size you'll need here, but it's small!)
-A file or coarse sandpaper
Steps
1. Here's the metal cap we'll be using:
And here's the threaded ring:
We need to center the threaded ring on this cap and then trace the inner circle of that ring onto the cap. We'll then cut that hole out. To center mine, I started off with this whole complicated plan of using geometry to mark the center of both things, but came up with something much simpler. Use a pair of scissors and your hand as a depth gauge, and then just keep moving around the cap until the ring is pushed in equally in every direction.
Eventually, the black ring will be equally close to the edge of the metal cap in all directions, and voila! It's centered. Trace the inside of the ring with a sharpie.
2. Cut out the circle you just drew. Drill a pilot hole so the saw blade can go in, and then cut the rest of the way around.
(Ignore the other smaller holes for now.) After the hole is cut out, go around the fresh edge with a file to knock down any burrs and smooth it all out. Sandpaper would probably also work here.
3. Drill holes in the threaded ring so it can be screwed to the metal cap. This is really the only step in the whole process that requires a good amount of precision. If the holes you drill are too far to the outside of the ring, the head of the screw will keep the etalon from threading on correctly. If the holes you drill are too far to the inside of the ring, the holes will be very close to the wall of the ring, which could weaken it. The heads will also be hanging out in the light path.
The heads of the screws are about 5.4 mm in diamter, so we want to drill the pilot holes 2.7 mm from the inner edge (5.4 / 2 = 2.7). Measure in with a caliper, then use a center punch to mark that location. This will keep your drill bit from wandering.
The red arrow is pointing to the little dimple where I used the center punch.
Once you've punched a bunch of dimples, drill all the holes. Use a 1/8" or a 3 mm drill bit.
I wasn't too concerned with making sure everything was perfectly symmetric around the ring. The only thing that mattered was that the holes were very close to 2.7 in from the inner edge. Even with the lack of symmetry, it'll still be plenty strong, and nobody will ever see it. :)
4. Transfer the holes to the metal cap. Not too much to explain here.
5. Bolt the ring in place. I trimmed the nylon washers with some scissors so they weren't hanging off the edge into the light path (that's what all the little plastic bits are).
6. Drill 4 holes around the circumference of the metal cap to accept the nylon thumb screws. You can use pretty much whatever size screws you want here. I used 1/4-20 because I had that tap on hand. If you use a 1/4-20 tap, you'll drill a 13/64" hole. If you use a different size screw and tap, then read the instructions for that tap to find what size hole you need to drill.
Once the holes are drilled, tap the holes so you can thread the nylon screws in.
7. Paint the inside of the cap flat black to minimize reflections.
8. Enjoy your new adapter plate!
It's attached securely enough with the four nylon screws that I can pull my tripod over before the cap can be pulled off. I'm probably still going to add felt inside of the cap, add two more nylon screws, and add a little leash so that it's all tied to the telescope, though. It would really suck if it all fell off. :X
The nice thing about this is that if I wanted to mount it to a larger or smaller telescope, I could just buy a larger or smaller metal cap, and transfer the threaded ring over to it. This would mean another adapter for <$20.
If anything is unclear, let me know! :rockon:
rsfoto
Has thanked: 9677 times
Been thanked: 5757 times
Re: DIY: SolarMax 60 Etalon Adapter Plate
Post by rsfoto »
:thumbsup: :thumbsup: :thumbsup: :thumbsup:
¿ How long did you work on that ?
kornfeld1
Post by kornfeld1 »
Thanks. I owe you some gratitude for showing how your adapter was made and letting me know what threads were on the adapter as well.
As for how long it took: several days of thinking about how I wanted to do it; but then only about an hour or two of actually working. There really isn't much to it:
-Cut out the hole in the cap
-Drill the holes so you can screw the ring to the cap
-Screw the ring to the cap
-Drill and tap holes for the nylon screws
-Paint the inside
That's about it! I went into extra detail here because I've taken a ton of information from the people on this board, so I wanted to give some back.
rbotero
Has thanked: 7 times
Been thanked: 9 times
Post by rbotero »
Good job Kornfeld! Nice step by step guide - B)
I am having a part machined locally to mount my DS SM60 on a donor 70mm semi-apo. I got a few quotes online ranging from £90 to £150! I found a retired machinist with a good lathe willing to do it for £25 in his spare time...let's see how it "turns" out! The most difficult bit was actually finding the aluminium blank to work on - that one was £10.
Roberto
gbealnz
Post by gbealnz »
Lots of DIY here, great. Nice job Kornfeld.
I too have just taken delivery of an adaptor to mount the SM60 on the Zeiss. Properly, instead of bits of tape I might add.
My threads were 82mm though, so does this mean they have changed the filter size?
Gary
kornfeld1
Post by kornfeld1 »
Gary
Funny you would mention tape....that's exactly how I had it mounted before I decided to/figured out how to put this adapter together.
It was surprisingly secure like that...I had a hard time taking it off. I wrapped the tape all the way around the rear-most ring of the T-max adapter, and then secured the tail of the tape to the dew shield on the telescope. Having said that, this obviously isn't a recommended way of mounting the filter to the telesccope.
As for the thread size...the 60mm etalons have 77mm threads on the inside and 82mm threads on the outside. I had an easier time finding a ring with 77 mm threads, so I went with that.
gbealnz
Post by gbealnz »
Ah, makes sense now, didn't check/know there were two threads.
Tape? don't get me started, I am too embarrassed to show you mine, I'm just glad I got an adaptor made, LOL.
Just need to work out where can I mount my "cloud filter"?
Gary
