Daystar Quark consideration
David Fox
Been thanked: 4 times
Post by David Fox » Tue Feb 23, 2021 3:31 pm
Hi there,
I'm considering the purchase of my first Quark and indeed first Daystar product & looking at the magnesium model.
wanting to keep my eyes for a while longer I'm confused as to when an erf is required. sky at night review on this model said ok to 127mm but I've seen 100mm referenced elsewhere.
my scope is 127ed esprit and i already have an uv/ir filter for the front of this proposed Quark.
the erf configuration in their site is down - fact a lot of content on it seems dated.
how safe am i with my scope mm?
Lunt 60tha
Lunt 50tha with DS
Lunt HW 2' on Skywatcher 120ed esprit for white light
TI Dome / EQ8r / solar quest / zwo 178mm.
Has thanked: 2108 times
Been thanked: 1959 times
Re: Daystar Quark consideration
Post by DeepSolar64 » Wed Feb 24, 2021 6:20 am
If I understand the Quark's instructions correctly no ERF is needed on a scope 80mm or smaller. You would need an ERF on a 127mm refractor to safely use it. I am wanting a Sodium D line Quark and was wondering the same.
Magnesium would be an interesting emission line to observe or image in. I don't see many here who do work in the magnesium band.
Has thanked: 3497 times
Been thanked: 1447 times
Post by marktownley » Wed Feb 24, 2021 6:39 am
Hi David.
I have a Na Quark and a 127mm frac, a 2" UV/IR filter on the nose of the diagonal is all that you need.
Has thanked: 1381 times
Been thanked: 1211 times
Post by Carbon60 » Wed Feb 24, 2021 7:49 am
Hi David,
Have you considered starting off with a white light setup (maybe you already have this)? WL wedges are a good starting point. After that then maybe hydrogen alpha. Magnesium won't really give you anything spectacular over and above WL. Just a thought.
David Fox
Post by David Fox » Wed Feb 24, 2021 9:41 am
thanks all,
I've the H wedge and polarizer on the 127 for white light and a couple of lunt ha's.
......of course with this hobby nothing never satisfies 😜 always a desire for more
would you be able to put the Quark into the eye end of the H wedge and provide protection? assume not.
Lunt 60tha
Lunt 50tha with DS
David Fox
Post by David Fox » Wed Feb 24, 2021 10:28 am
sorry just see the response to my second question from the daystar manual;
''Please note, a Herschel Wedge or white light filter cannot be used with
the Quark. These filters pass very little light by design and so will result
in an extremely dark image if used with the Quark''
Lunt 60tha
Lunt 50tha with DS
