Lunt Ca-K B1800 module in focuser?
Stardust5858
Has thanked: 312 times
Been thanked: 379 times
Post by Stardust5858 »
Hi all, I came across a problem today with the Lunt CA-K module wedge. On my revelation 80ed the focuser has a tiny lip inside preventing the lunt module to only go in 50mm. Is it safe to use like this as it's not fully in if it reaches focus?
I used my 70mm Stellaview today which enables the module to go fully in.
Appreciate any thoughts.
Nigella
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Nec6 Eq Mount.
EGRAY_OBSERVATORY
Been thanked: 1677 times
Re: Lunt Ca-K B1800 module in focuser?
Post by EGRAY_OBSERVATORY »
Hi Nigella, I would have thought, that if the module locks in with the thumbscrew tightened, then that should be okay and when available-weather, see if focus is achieved, both with EP and Camera. 50mm/2" seems quite away-in... I can't see any safety issue thru the CaK module that way.
From what you describe, it is likely that the scopes draw-tube just won't need to travel-in as far as one might expect to be in focus...
I hope all is well there and no doubt you will show us - all is well.
Has thanked: 4060 times
Been thanked: 1781 times
Yeah it's fine!
