Hello SCF!
I am in the process of upgrading my solar imaging. I want to image H-alpha with a Quark chromosphere filter, and am considering a ASI174mm which would fit my Quark on an F6 refractor.
I was also considering a Basler camera on the lines of GreatAttractor''s Lunt50THa mod to a 90mm scope (see Modifications section): He was using the :
""Basler CM3-U3-13S2M-CS. Parameters aren't very impressive compared to newer cameras, but it shows no image artifacts in Hα or CaK, unlike many current CMOS sensors - no Newton rings, fixed-pattern noise, Bayer-mask-like nonuniformity on mono models due to fabrication or firmware issues. Reading about all that made me very wary of upgrading to something bigger and faster.""
I checked with the EdmundOptics online shop and they don''t have this model anymore.
Can anyone recommend a present day camera like this, not too expensive. I wonder if this camera would work on a Quark and F6 refractor, or would it work only on the 90mm mod to the Lunt50THa (GA''s modified scope) ?
I really want to avoid Newton Rings, I understand the ASI174mm still has this as a problem.
Would the Basler camera have Newton Rings at high Focal ratio e.g. F25.2 (i.e. F6 refractor with a Quark).
Thank you.
Magnus
Basler camera advice CM3-U3-13S2M-CS
- Radon86
- Has thanked: 763 times
- Been thanked: 663 times
Cameras: ASI120mm-S,ASI174mm
Accessory: SW Auto-focuser
- GreatAttractor
- Has thanked: 748 times
- Been thanked: 757 times
Re: Basler camera advice CM3-U3-13S2M-CS
Correction: it's not Basler, but FLIR (formerly Point Grey). Their online store shipped very quickly within the EU the few times I ordered there. (But it would probably be more complicated for the UK in the current situation.)
Regarding potential Newton rings at high F-number: I wouldn't expect it, though I've only used it at f/16 in Hα and ~f/18 in CaK.
As for using it in other setups: check this post by MalVeauX about critical sampling. In general, it's OK to have somewhat too big pixels (increasing the image scale with a Barlow is practically lossless in terms of quality); but tiny pixels require a focal reducer, which may give worse quality.
- Has thanked: 20938 times
- Been thanked: 10587 times
Rupert has these in stock:
https://astrograph.net/epages/www_astro ... PGCM-31S4M
As to whether you get Newtons rings it is difficult to say, they're very system dependent. A small pixel camera will work better with shorter focal ratios, a larger pixel camera (like the 174) will work better with longer focal ratios - eg Ha Quark.
