I'm awaiting delivery of a Solar Spectrum 0.3A research grade 18 mm etalon from Alpine Astronomical. I ordered the TZ-4 and the required adapters for use on my CR-6, F/8 refractor. I will probably be masking this down to 100mm or less as my seeing rarely supports the 6". I have a tri-band D-ERF from Aries. Does anyone suggest a sub-aperture ERF like a Ha or Red-IR filter for more protection? I was also wondering about double stacking with a SM2 90mm etalon. Has anyone tried this? If I use it on my F/7 102mm scope, is the ERF of the SM2 etalon sufficient protection?
I read the "manual" to familiarize myself on its use. The instructions could be more helpful with some pictures. How sensitive or adjustable is the heater/cooler? Are there any tricks or nuances that may need to know? Any advice or help will be much appreciated.
Solar Spectrum advice, tips, do's and don'ts
- hopskipson
- Has thanked: 404 times
- Been thanked: 191 times
- Has thanked: 2 times
- Been thanked: 58 times
Re: Solar Spectrum advice, tips, do's and don'ts
It should be more than okay "just" to use the Aries filter. When you have a first class h-alpha filter with superb finesse, spectral uniformity and bandwidth you should be aware that using a SM2 can introduce some aberration problems. If I look in my SS 0.3A filter I can not think of any devices that can improve the performance except making the focal length even longer - greater than f40. Its on band after a few minutes and stable a few minutes later. You can adjust the temperatures up and down and see the wings. It will take some minutes to get -+.5A.
Not really. If you want some more in deep explanation look at a Quantum manual from Daystar. It works nearly the same way except Mark have this feature to cool the filter if it begins to drift to the red wing.
- Has thanked: 175 times
- Been thanked: 426 times
I don't find it useful to stop down my 6" f/7 for my RG32 0.3A Solar Spectrum, and I am not in a super seeing location. Either the seeing is there or not, and stopping down doesn't fix it for me.
I use a Baader DERF. I don't use a sub-aperture ERF, and Mark W generally recommends against the duplication as superfluous. Remember it has its own ERF.
I do double stack my Solar Spectrum with a Lunt DSII unit. It eliminates the double limb and adds detail on the disk without losing proms. It just makes the normally wide sweet spot a little smaller. If I want the full >30mm aperture view through my binoviewers, I go SS, but if I am willing to cut down to about 28mm, I do DS.
George
George
