I knew he was just trying to trick me. When he mentioned he double stacked his Baader Continuum filter for better results, I had to try this myself to see if it was true! I do indeed have two filters of this type, and below the results are very clear. NO IMPROVEMENT WHAT SO EVER. In fact, the image was Four stops darker! that made the exposure so long as to blur the images significantly as well. But alas, no boost. Here are the results side by side. Click on it for the full size version:
Walter you sly devil you! It might have actually worked...
Walter ALMOST had me on this one!
Chris Schur
- mr40mm
Re: Walter ALMOST had me on this one!
Yep!! sometimes More is Less. Randy
Astro-Physics 152mm F8 with 1200 mount, SkyWatcher 100mm F10, Celestron C-8, Baader Herschel Wedge Model P, DayStar Quantum PE .5 Angstrom, PGR FLEA-2 CCD video camera, Meade 14" RC with Astro-Physics 1200 Goto mount.
Hi Chris
a fine comparison. Indeed you seem not to get much improved results doublestacking the baader continuum filters. Mhh
But that is not hindering me to use my double stack. Maybe I can use it today again ;-) Let's see
Walter I was getting some really long exposure times with the double stack, like 1/8 sec. Not good for freezing the seeing...
Chris Schur
Hi Chris
you are right. The transmisson is lowered, but it doesn't matter with a 8" lens ;-)
- Has thanked: 20424 times
- Been thanked: 10242 times
Take the ND filters out of your wedge
Hi Mark
that is a good point if it is still there
