1083nm filter for He-I imaging?
Cschur
Post by Cschur » Tue Jul 09, 2013 4:26 pm
Mauna Loa solar observatory always posts these killer full disk shots with one of these, but does not say much else.
http://mlso.hao.ucar.edu/index.php
Now I next went to Omega optical filters on line, and found they do have a 1080nm filter, looks pretty broad however at around 180nm band pass. Anybody do research on this? I know that my ST10xme has just enough bandpass to image at this wave band, but I suspect it may take an ultra expensive 1nm filter. Any thoughts?
Chris Schur
Re: 1083nm filter for He-I imaging?
Post by swisswalter » Tue Jul 09, 2013 5:21 pm
Hi Chris
thanks for the information. I'm always looking for new filters, at the Moment I'm on the short side of the recordable wavelength with our means ;)
Post by marktownley » Tue Jul 09, 2013 5:25 pm
I think an ultra expensive one will be needed - they talk about it being a Lyott filter on their website, they aint cheap!
brianb11213
Post by brianb11213 » Tue Jul 09, 2013 6:02 pm
Another major issue here: the sensitivity of the silicon based sensors that most of us use is practically zero at 1083 nm ... so it would need a special camera as well. Spherochromaticism in our "visual" instruments is going to be a serious issue but lack of useful response from the sensor is probably going to be many times worse.
Cschur
Post by Cschur » Tue Jul 09, 2013 6:12 pm
Well, so much for that idea! :(
Chris Schur
BelOptik_Oliver
Post by BelOptik_Oliver » Tue Jul 09, 2013 8:42 pm
Hi sunbathers :)
The "ChroTel" near VTT (Tenerife) use also three ultra narrowband Lyot filters and one of this is tunable.
http://www.kis.uni-freiburg.de/index.php?id=457&L=1
And here is description of filter and assembly:
http://instruments.hao.ucar.edu/ChroTel ... iption.pdf
Btw, Andover Corp. had in past times on his surplus filter side a NIR filter 0.5nm FWHM (too far) @1083nm offered for 620US$.
Clear skies! Oliver
Coronado PST, SM40 DS module, BF10, BF15
95mm F10 Chromat (aspheric corrected single lens), ERF105
120mm F8.5 Chromat (aspheric corrected single lens), ERF125
2.5x & 3x & 3.5x & 4.5x Telecentric, H-alpha system
"UV/IR cut on KG3" blocking filter
Prominence viewer with Ha or Hb filter
...and for the night: 8"f6 Lightweight-Newton (4Kg)
