Double stacking question
gabrieli
Post by gabrieli » Tue Aug 27, 2013 10:50 pm
Given the surge of double stacked images, I'm looking at double stacking my LS80 with an external etalon, likely an LS60FHa.
If I use the LS60FHa on the LS80, would it be safe to remove the internal ERF from the LS80 in a double stack to improve the brightness? I'm assuming the ERF in the LS60FHa would be enough to remove most of the heat causing IR.
I would also use it on a 102 mm refractor and double stack it with a PST etalon at the camera end of the scope..
Lunt sells one version they say is only for double stacking an existing etalon or solar scope. It can't be used on its own.
Does that mean that it is missing an ERF(already in the pre existing etalon) or is there something else at work?
Note: I haven't looked through an eyepiece in years. So any hazard would not be to my eyes.
Re: Double stacking question
Post by swisswalter » Tue Sep 03, 2013 8:41 pm
Hi Lou
I don't see any problems but I would remove the external ERF on the double stack filter
Allcart
Post by Allcart » Tue Sep 03, 2013 11:06 pm
Hi Lou
But don't remove it if you are using the LS60f on the 102. You will need the erf up front.
Allan
Post by swisswalter » Wed Sep 04, 2013 3:45 pm
[quote]Hi Lou
Yes Allan is right. You do need always at lest one ERF, the position of it is not that critical as long as it is up front of the first glas or filter near the focus
Robin
Post by Robin » Wed Sep 04, 2013 5:58 pm
I also have a 102mm Megrez which I am considering obtaining a plate and fitting my LSf DS on the end I hope to use my existing B1200 in conjunction. I assume this will give good results. I also assume you have a BF as well for your setup
Lunt LS60THa / B1200 / LS60Fha / DMK51AOU2 / DMK21AOU2 / Revelation 6 & 8" RC / Opticon Minitower 11 & Startracker / Mad Red Setter and understanding Wife
