Lunt herschel wedge or baader herschel wedge
Hi everyone..
Maybe this question it's commun but, I want to ask witch one it's better to get for photography with my DMK51.
I try the Lunt one time but just for visual.
Thanks for all the answers.
"I'm enough of an artist to draw freely on my imagination. Imagination is more important than knowledge. Knowledge is limited; imagination encircles the world."
--Albert Einstein, October 26, 1929
EQ:
Double stack 60mm Coronado ( pre-meade ) H-alpha filters with a 15 blocking filter.
DMK 51AU02 the imaging source Mono CCD camera.
Orion Short 2x Barlow.
Explore Scientific 102mm f/7 Air-Spaced Triplet ED Apochromatic Refractor Telescope.
Astrotelescope ( Planet Killer ) 102mm f/11 hand corrected doublet. Refractor Telescope.
Losmandy - G11 ( Gemini 1 )
FireCapture, AutoStakkert 2, PixInsight, Registack 6 and Photoshop CS 6.
EQ:
Re: Lunt herschel wedge or baader herschel wedge
Performancewise they're pretty much the same. The packaging is different & the newer version of the Baader wedge has a translucent ceramic heat sink which allows it to act as its own solar finder. Whether this is worth the price difference is up to you.
I know. The price it's the BIG deal here. But, I want to know if the granulation and detail are similar or what? :woohoo:
EQ:
EQ:
- Has thanked: 20424 times
- Been thanked: 10242 times
The views will be identical. The baader (photographic version) allows more flexibility from an imaging point of view, wheres the Lunt is a bit cheaper, I think...
Thanks... It's a pain no to have one of each one and compare by myself. lol
EQ:
EQ:
There's a huge price difference here in the US. The Lunt 1.5-inch is $219, the Lunt 2-inch is $288, the Baader visual is $639 and the Baader photographic is $719. The Baader photographic comes with a lot more stuff, including several ND filters and Continuum filter. Both the Baader photographic and visual are also more flexible with removable filters as well as removable front and back ends with "T" threads.
- Has thanked: 173 times
- Been thanked: 615 times
Whoooo That's a hellava price difference!!
I'm a very happy Baader Herschel Wedge user, mounted on the TS102 f11.
[quote]The views will be identical. The baader (photographic version) allows more flexibility from an imaging point of view, wheres the Lunt is a bit cheaper, I think...
Wow. I knew that the Baader was expensive... But not that HUGE difference in price.
EQ:
EQ:
Strange those prices I just got one here in Australia for $680 and that's the P version the V version is $620
Well. At the end if I get the Lunt one u think I'll get good granulation and details?
EQ:
EQ:
aboy,
If you're using a telescope of 100mm aperture or greater...under good seeing conditions you'll get good viewing of the granulation etc etc with either of these Herschel Wedges....
Thanks Merlin. I get the telescope what you suggested the Astro-telescope 102mm 1100 f/l
So I think I'll try the Lunt one.. Money issues.. :S
EQ:
EQ:
Hi Herb
you will be happy with both of them. Take the best offer
