Ca K telescope
TheHubby
Ca K telescope
Post by TheHubby » Sat Jan 11, 2014 6:30 pm
Since I favour Calcium K, I would like to upgrade from the CaK PST (since I can never get on it).
Alexandra suggests this Exp Scientific 102mm http://www.telescopehouse.com/acatalog/ ... ntial.html with a CaK module from here http://luntsolarsystems.com/blog/cak-modules
would they work OK together?
The hubby
Negative comments welcome to aid learning, as competing with Alexandra on her old borrowed equipment means I will always be 3 steps behind.
Has thanked: 1542 times
Been thanked: 617 times
Re: Ca K telescope
Post by marktownley » Sat Jan 11, 2014 7:10 pm
Hey there! :)
A nice scope, however I would save yourself a whole load of money and get better results by getting a simple fraunhofer refractor for CaK - they work better than ED scopes or triplets. Counter intuitive I know, but the simpler glass and optical coatings are much better at the shorter wavelengths.
You could consider a Tal100R http://astronomia.co.uk/index.php/teles ... scope.html or a Celestron Omni XLT 102 http://www.firstlightoptics.com/omni-xlt-series.html You saw my 100mm Tal at the International Astronomy Show. These are the only two 100mm scopes I would get for CaK work.
mark
Re: Ca K telescope
Post by swisswalter » Sat Jan 11, 2014 7:43 pm
Hi Hubby
I second Mark's opinion. A simple achro is good in combination with a LUNT B1200 and the secret filter of the PST added will top every thing ;-) :hamster: :hamster: :hamster: :hamster:
PS. That combo also works on a WO 110 ;-)
Re: Ca K telescope
Post by marktownley » Sat Jan 11, 2014 8:09 pm
One more thing to add, if you do want to spend big bucks on a scope then a frac with a fluorite lens is better still than a fraunhofer...
Re: Ca K telescope
Post by swisswalter » Sat Jan 11, 2014 8:20 pm
Hi Hubby
I second what Mark wrote. My TAK 102 works very well with my Klunt filter combo and would work even better with the CaK PST filter added to the combo ;-)
Has thanked: 1445 times
Been thanked: 487 times
Re: Ca K telescope
Post by Montana » Sat Jan 11, 2014 10:12 pm
Hey chaps, you are starting to speak another language :? I was hoping to get him something similar to a CaK PST but a 60-80mm version, however I have found that Lunt don't do an all in one CaK scope. So I was hoping there would be something small, simple and compact for easy set up etc. Finding a CaK PST seems to be impossible, something like a TAK is also impossible Walter.
Does Joe Sullivan use the Celestron 102? I am not sure if the C102 is a code for this what Mark suggested?
Thanks for your help guys :)
solarchat
Site Admin
Site Admin
Has thanked: 6 times
Been thanked: 58 times
Re: Ca K telescope
Post by solarchat » Sat Jan 11, 2014 11:13 pm
Montana-man
Lunt certainly does do an all in one CaK scope. They have a line of white light doublets that are very reasonably priced and they will sell you a Lunt B1200 and a 60/80 or 100mm refractor with it if you want.
I personally use the exact thing Montana-woman recommends for outreach and all my imaging, the Exp Sci 102mm APO and B1200 CaK .
feel free to email rikki at Lunt to get whatever you want headed your way. I would suggest that if you are going ahead and buying a refractor / CaK setup that you add a Lunt white light wedge to the deal all together. They are less than $300 and will allow you to quickly switch out diagonals for white light or CaK.
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Re: Ca K telescope
Post by marktownley » Sat Jan 11, 2014 11:20 pm
Yes, Joe Sullivan use a C102.
You can get the CaK scope over here http://www.iankingimaging.com/show_product.php?id=1095
Personally if that is the route you want to go I would get just the diagonal and then maybe a 60-70mm frac to go with it - will work out alot cheaper and you could use it as a spotting scope for birding.
hunterknox
Re: Ca K telescope
Post by hunterknox » Sat Jan 11, 2014 11:45 pm
I went through quite a few 4" refractors when I was in my PST modding phase. The Tal's a very good achromat - a little rustic in terms of the mechanical build and finish but it terms of the optical quality it's definitely a cut above the Celestrons and Skywatchers in a similar price bracket (or at least the examples I tried).
It's also worth considering the Lyra Optic f11, which is mechanically superior and has a pretty decent dual speed focuser.
If you can deal with the long focal length and resulting image scale I'd go for one of those two. If not then, like Mark says, something smaller may be a better idea.
Re: Ca K telescope
Post by Montana » Sun Jan 12, 2014 12:21 pm
Thanks for the info, we were having a good chat about it over breakfast. I thought Stephen had the Explore Scientific.
Mark, they are very expensive for a 60mm, it would be better to get 100mm for the same price. I asked what he enjoyed doing and it seems looking at the spots up close so I think 80-100mm would be better. It is very interesting the Celestron works very well as we would be able to get this from Rick at Stockport Telescope shop, I prefer to keep him in business. We need to do some measuring up to see if it will fit in the dining room, as hubby needs it to be permanently set up and ready to go (he doesn't like fiddling about). But the Celestron looks very long and he doesn't seem too keen.
Next problem is the Lunt module, I am not sure that Rikki will deal with me as I am from Europe, last time I tried a few years back they pushed me to deal with Lunt Europe and they are 3x the price of the US (not including our tax). I will have to see how much Ian King would sell us one for and try and compare the price, we have no problem importing from the US (if allowed) as we have done this before with the TEC. It will need a few inquiries.
Does Rikki have a direct e-mail? just to increase the chances of not being ignored and forwarded to Lunt Europe?
Many thanks
Alexandra and hubby
Re: Ca K telescope
Post by marktownley » Sun Jan 12, 2014 1:01 pm
Ahhh, regards the scopes then, if SBTC is going to be getting some business I would recommend in my order of preference:
1) http://www.telescopesandbinoculars.co.u ... -1474.html - Walter has one of these, i'm sure he'll tell you his thoughts on it.
2) http://www.telescopesandbinoculars.co.u ... -1256.html
3) http://www.telescopesandbinoculars.co.u ... -1255.html
For a bit more aperture they sell my original recommendation http://www.telescopesandbinoculars.co.u ... -1723.html
Regards the Lunt wedge I would just order direct from Teleskop Service in Germany, they have them in stock currently http://www.teleskop-express.de/shop/pro ... cuser.html I've bought from these (high value items) a number of times and can only whole heartedly recommend them, there are also no associated customs charges to pay either...
HTH!
Mark :)
solarchat
Site Admin
Site Admin
Re: Ca K telescope
Post by solarchat » Sun Jan 12, 2014 2:00 pm
Hocking Rikki
its not that the prices are 3x higher for nefarious reasons, its just the massive amount of government tariffs imposed on imported items. I have the same problem with the $40k worth of solar gear going to Australia. Having to pay almost the full retail here in the states on top of buying it to get it into Oz.
Stephen W. Ramsden
Atlanta, GA USA
Re: Ca K telescope
Post by Montana » Sun Jan 12, 2014 5:18 pm
Thanks guys :thanx:
We need to do some research and measuring now :)
Re: Ca K telescope
Post by marktownley » Sun Jan 12, 2014 5:34 pm
No worries, keep us updated as to proceedings :)
robert
Has thanked: 1 time
Been thanked: 51 times
Re: Ca K telescope
Post by robert » Sun Jan 12, 2014 5:39 pm
I use an Skywatcher ED80 with a Lunt600 CaK module and it is really good. The module fits an ED100 as well and is great.
Robert
2020 images https://tinyurl.com/v6muwvm
sullij1
Re: Ca K telescope
Post by sullij1 » Tue Jan 14, 2014 3:50 am
Hi, Sorry I missed this thread. Send Hubby my regards.
Yes, I use the Celestron 102, and yes, it is very long. It is not a grab and go sitting in a corner of the family room. The tube sits in the corner in a nice bag next to the mount. It all has to be hauled out and set up. Takes about 15 minutes to get up and running.
I Like Stephens suggestion for a grab and go.
Gotta say that the Celestron 102 isn't that much of a hassle to set up. (the images coming from it ROCK!)
My Celestron 11 inch and CGE are a hassle to set up. My back tells me so. :lol:
I also recommend the Rigel NFocus, focus motor. Makes focusing from under a hood Soooooo easy.
Stay with the B1200 and B1800 size Lunt modules. Brightness matters, so does the FOV when trying to keep the full disk in the Field Of View.
I hope you find an affordable easy solution in the UK.
Look Up!
sullij1
Re: Ca K telescope
Post by sullij1 » Tue Jan 14, 2014 4:08 am
One more thing - When Astrodan let me use his Explore 102 to shoot with, I must say that it was easier to handle than the C102 and although the Explore produces a slightly softer image(probably due to shorter focal length), it was a very nice kit. The image softness can be fixed in post processing.
Look Up!
sullij1
Re: Ca K telescope
Post by sullij1 » Tue Jan 14, 2014 4:42 am
Hubby,
OK, now ya got me going. Seeing how ya are gonna lay out a pretty penny for this I will give ya some observations. First, these are my opinion and I am not in any way trying to denigrate any colleagues’ work or implying I am the expert. Just observations.
I say go with the K-line B1200 or B1800 or B3400 because as I look at the imagery coming from the smaller B600 and smaller diameter and shorter focal length/ratio scopes, it seems the smaller the optical components, the more one loses the umbra and penumbra details in the image.
I changed my order from a B1200 to a B1800 and am soooo happy I did. Financially it hurt!!!!! But the imagery I am getting speaks for itself. I am not sorry I went for the larger filter, especially when I go after the 5X images. In my opinion the longer focal length, larger filter and aperture are making all the difference.
I will be happy to post via you tube, raw imagery etc. to demonstrate my point or show ya what the image looks like at higher magnification if that is what you are looking for. Really just want you to be happy with your purchase.
Best,
Joe
( please excuse crummy spelling and red neck dialect.)
Look Up!
Derek Klepp
Been thanked: 146 times
Re: Ca K telescope
Post by Derek Klepp » Tue Jan 14, 2014 7:58 am
I picked up a cheap ED 102 which is easy to set up and haul around.I am happy with my B1200 but Joe has a point on the variances between them.Basically my B1200 sits on an 80mm f6 APO for quick discs. As you guys travel I think a good 100mm that could go with you or even a 90 may be the go.One has to also look at the versatility of the scope you are purchasing or you end up with a lot of glass that doesn't get used enough.I would also get Pedros view on this as he has tested a lot of scopes with CaK.Just my two bobs worth.Also and I'm out on a limb here do you need to consider a unit that on occasion will be put on the TEC 140.
Cheers Derek
astrodanco
Re: Ca K telescope
Post by astrodanco » Wed Jan 15, 2014 8:35 am
To echo what Joe said, imaging outside in the bright sunshine doesn't work for me. I remote everything into the house. I have cables for the mount, focus motor and camera all running indoors. I've been using the Rigel Systems nFocus DC focus motor and hand controller. Some people might prefer the stepper motor version.
Re: Ca K telescope
Post by Montana » Wed Jan 15, 2014 10:12 am
Thanks guys for the wealth of information :)
We had a long discussion last night and nearly settled on the Celestron 102 but then couldn't find a simple mount for it. They all come with an equatorial and he wasn't too keen on that. All the alt/az require short tubes. So we went round in a bit of a circle :( back to the drawing board of thought again.
astrodanco
Re: Ca K telescope
Post by astrodanco » Wed Jan 15, 2014 10:48 am
You can purchase a C102 OTA from OPT for US$99.95 (see here) without any mount and then place it on whatever mount you like. The stock C102 OTA has a short Vixen dovetail that works with any mount with a dovetail saddle that can accept a Vixen dovetail. Or you can purchase a #102CLSCCRDL cradle ring from Explore Scientific for US$51.99. Just place a few rubber washers on the knobs to make them clamp tight onto the C102 OTA.
C102 OTA from OPT:
Cradle Ring from Explore Scientific:
Oops, just noticed that's an OPEN BOX item there at OPT.
Re: Ca K telescope
Post by Montana » Wed Jan 15, 2014 12:31 pm
Thanks for that info :) it's not just the buying it separately bit, we can't find a mount other than the equatorial one which will take a 1 meter tube ;)
Re: Ca K telescope
Post by swisswalter » Wed Jan 15, 2014 6:35 pm
Hi Alexandra
don't worry. I have a Losmandy GM8 left for sale, only 800 €. But it will cary 3 of your scopes ;-)
Re: Ca K telescope
Post by marktownley » Wed Jan 15, 2014 8:36 pm
Ahh, you have your alt/az Ioptron(?) mount don't you - take it you want to use that? simples then, a 70mm f6 ed scope - something like http://www.altairastro.com/product.php? ... 270&page=1 spend the money you save on the scope on bigger blocker cak filter...
