This is the USB 3 mono version of ZWO's ASI 120 series. It's an excellent lunar and planetary imager. It's also an excellent white light solar imager. It's very good in H-alpha as well provided a tilt adjuster is used to eliminate Newton's rings. For images, see my astrobin page (bunyon is the username there as well). Solar images from about two weeks ago and older are with this camera.
The camera is also an excellent guide cam.
Included is the camera, nosepiece, wide angle lens for use as a webcam or all-sky camera, USB 3 cable, ST-4 cable. The camera has a USB 3 port and ST-4 port. The camera can be used with a USB 2 port on a laptop but not with a USB 2 cable.
I also have for sale the tilt adjuster I use with H-alpha imaging. It is most likely necessary as the camera has some issue with Newton's rings. With the tilt, it's fine.
Camera (and bits): $350
tilt-adjuster: $70
Bought together: $400
Cost includes shipping in CONUS. Will ship international if buyer pays shipping.
Paypal only.
ZWO ASI120MM-S and tilt adjuster
- The Sun?
- asi120mms 2.JPG (142.37 KiB) Viewed 4886 times
- asi 120mms 2.JPG (144.91 KiB) Viewed 4886 times
Re: ZWO ASI120MM-S and tilt adjuster
Hi Paul
good luck on the sale
- The Sun?
Thanks!
All, the camera has sold. The tilt adjuster is still available. I bought it from OPT and have used it to minimize the newton's rings on the ASI120MM. If you have a setup with a ring problem, this may help.
- yltansg
- Has thanked: 1446 times
- Been thanked: 1423 times
Hi Paul,
I am interested in buying your tilt adjuster.
Dropped you an email.
- The Sun?
yltansg - I'm so sorry. I've been travelling and hadn't checked in with solar chat for a few days.
I've received no email. Please try again and I'll search spam (we just changed spam filters at work with a lot of disruption). If you're no longer interested, I understand. Again, sorry for the delay.
- The Sun?
- yltansg
Hi Paul,
I have transferred the funds to you 2 days ago. Please let me know if the transfer is in order.
Alfred
Alfred
