Wanted-Part for Solar Max 60
VENDORS WELCOME! Please, only solar equipment.
mselph
Post by mselph » Tue Feb 21, 2017 12:24 am
Wanted - Part for Coronado Solar Max 60, telescope bought in 2009--- FOCUSER DRAW TUBE
Explanation -- I accidentally damaged the drawtube for this telescope, although it still works, but not very well. Maybe somebody has one for an 2009 scope which is otherwise broken? I ordered a replacement from the manufacturer, but they sent a complete focuser assembly instead, which is a little different from mine, and does not fit my scope.
( P.S. ) I dragged one photo twice, since it did not show up on the screen, so thought it didn't work.
drawtube 2 -resized.jpg (100.58 KiB) Viewed 770 times
drawtube 1-resized.jpg (78.83 KiB) Viewed 772 times
Re: Wanted-Part for Solar Max 60
Post by marktownley » Sat Feb 25, 2017 10:57 am
What is wrong with the broken one?
mselph
Post by mselph » Sun Feb 26, 2017 11:06 pm
The damage occurred because one of the plastic screws which hold it in place at the desired focus ( there are 2 altogether ) broke off inside its hole, and every method I tried ( many ) to get it out, failed. It was just too old, I think. So the end result was 1) damage to the threads inside the screw hole so that it now longer accepts any screws ( I got new ones from the manufacturer ), and 2) bits of broken screw that fell inside the focuser ( the focuser cannot be taken apart ), which sort of inhibits its motion when the inside part is moved to get a good focus.
However, it can be held in place with the remaining screw usually, and it can be focused with some difficulty.
