Solar Bino-Scope: Lunt ST100 and Stellarvue ST110ED-BV, Amazing!
VENDORS WELCOME! Please, only solar equipment.
zlanguy
Post by zlanguy » Wed Jul 19, 2017 10:16 pm
For Sale - Solar Bino-Scopes for Solar Viewing of a Lifetime *** $9995.00, located in SF Bay Area, California, USA.
Due to an unfortunate turn of finances I am forced to sell off the most amazing telescope set up I have ever owned or that I have personally had the pleasure of seeing and looking through.
This amazing pair of telescopes and accessories provide absolutely astounding views of the sun. The pair of telescopes include the following two configurations.
A nice 110mm refractor that is binoview ready, can be made longer or shorter by adding or removing an extension included extension tube. The Stellarvue ST110ED-BV makes a really nice refractor for night time stargazing or by using the Lunt Wedge or a full aperature filter over the front of the telescope makes a very good white light telescope for viewing the sun's photosphere where sunspots, granulation and other magnetic activity can be seen.
1. Stellarvue ST110ED-BV (Binoviewer Ready)
This is outfitted with a 2-1/2" Stellarvue fine focuser. This is a really nice all around 110mm refractor which is very flexible. There is an extension tube which can be easily removed to shorten or lengthen the telescope to make it work with binoviewers without a corrector, or work normally with a regular single eyepiece. When using the Lunt White Light Wedge, it is an outstanding solar telescope.
Accessories include:
Lunt Solar Systems 2" White Light Solar Wedge
Baader Systems 2" Continuum Filter - to enhance sharpness
Denkmeier Gen II Binoviewer 1-1/4" nose
2 ea. 20mm eyepieces
1 ea Stellarvue Finder Scope, bracket and riser.
A dedicated 102mm H-Alpha refractor with a straight thru 34mm blocker. This is an amazing h-alpha refractor. The size of the solar image, the resolution, the detail.. it is just breathtaking.
2. Lunt LS100THA Solar Telescope
B3400 Package - with 34mm Straight-Thru Blocking Filter
Denkmeier Gel II Binoviewer 2" nose
Denkmeier 2" (OCS) Optical Correction System
Denkmeier short 2" diagnal
2 ea. Televue 24mm Panoptic eyepieces
1 Televue SolFinder for proper easy alignment with sun
Other accessories include:
Tripod includes a Desert Sky Astro DSV-1 dual alt-az mount
Heavy Duty Surveyor style tripod with quick set spreader bars
Manfrotto Tripod Case
Total invested over $12,000.00
Also included:
Large Case for tripod head, counter weight, and accessories
Eyepiece case
When these telescopes are mounted side by side as a "bino-scope" using the Desert Sky dual alt-az mount they provide views of two layers of the sun side by side. Different information side by side. It is amazing. It is easy to set up and really fun to use.
When properly balanced by adjusting both scope position in the two clamps on either side of the mount, and by adjusting the counter weight, the scopes can be easily moved by turning big knobs or secured by a twist clamp lock, and easily moved by hand as the internal bearings are very smooth.
With both cases, the tripod bag, and the telescope cases there are 5 items to ship. Buyer pays shipping costs if any.
For payment, cash is preferred, however, I do have a paypal account so I am able to accept payment by paypal or credit card if that is convenient.
Local sale and delivery to the San Fransisco bay area, willing to travel with in reason, maybe a few hours further if you pay the gas.
Thanks for looking, Michael
