Truss Solar Newton T250 for Ha and CaK
allhoest
Post by allhoest » Tue Sep 11, 2018 6:55 pm
I'm renewing some of my equipment. I bought a camera and FSQ106 and will probably go for a bigger solar scope also.
From my astrogear, the solar newton is for sale.
Works also with the solar continuum
Works also under the G band (430nm)
The truss tube and mirror are made by Martini Optik
The truss tubes and upper cell are stronger than standard models, to cope with the constraints of a Halpha setup.
The mirror is "multilayer" treated, to reflect the red and part of the deep blue wavelength.
Leaks allow imaging with a solar continuum
The spider is a rigid "double" carbon model
The secondary is a Lambda/20 made by Antares; it has a small damage on one end, not affecting the imaging process.
The focuser is a high quality from Starlight Instruments
Remote focusing through USB_Focus and heavy duty motor
Price: 2500Eur
Equipment available from Belgium.
Contact: allhoest@scarlet.be
Images made with this setup:
Re: Truss Solar Newton T250 for Ha and CaK
Post by marktownley » Tue Sep 11, 2018 8:18 pm
Super scope! Good luck with the sale!
allhoest
Post by allhoest » Fri Sep 14, 2018 6:17 pm
Thank you for the comments.
Some words about the system.
Optically, the design values are: F/D ~7, to be combined later to a telecentric x4 and come to high focal ratio number for imaging with a Halpha etalon.
D is ~250mm; F is about 1700mm.
The principle is a herschell prism, reflecting 4% of the incoming light flux. There is thus no aluminum coating.
The remaining 96% flux pass through the mirror. The mirror supporting structure is as open as possible, so no heat can build.
It works very well, acting as a giant herschell prism.
The open structure minimize (cancel...) the internal "tube" turbulence.
The mirror also is not heating up (less than 2°), to minimize local turbulence.
The open truss concept works well.
Above of this, the mirror is multicoated to reflect the red (Ha) and blue (CaK) domains. It becomes a special herschell prism.
It reflects flux in the G band (430nm).
It reflects a leak under the "baader continum 540nm", acting as a regular herschell prism.
The multicoating technique is a vaccum deposit of several (many) well calculated oxide layers, to have interferential destruction of some wavelengths. This coating is very resistant it should last for ever.
