Today's SUN (20181116) with good seeing
pedro
Has thanked: 14 times
Been thanked: 6684 times
Post by pedro »
WEBLINK:
http://re.apaaweb.com/sun_h_alpha_2018-11.html
Great seeing today and a nice small AR. Tried the SM90II again and got better results.
Check out the HR WL images with the TEC140 (X5 Powermate)
Solar Imaging Session (20181116) | Pedro RE'
TV101, LUNT60, TEC140
GS3-U3-28S4M, GS3-U3-28S5M
Takahashi EM-400
TEC140, BF30, GS3-U3-28S5M
H-alpha Full Disk (four-pane mosaic)
TEC140, GS3-U3-28S5M
HR, WL, X5 Powermate
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
OBSERVATORIES (DJI INSPIRE ONE)
SUN (20181116) H-alpha. TEC140 F/7, SM90II, BF30, PGR GRASSHOPPER 3 GS3-U3-28S5, four-pane mosaic
SUN (20181116) HR WL. TEC140 F/7, X5 Powermate, PGR GRASSHOPPER 3 GS3-U3-28S5
SUN (20181116) H-alpha DISK & PROMS (09:30 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4
SUN (20181116) H-alpha DISK & PROMS (09:30 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4
SUN (20181116) CaK PROMS (09:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20181116) WL, CaK & H-alpha (09:30 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPE 3 GS3-U3-28S4M
pedro
Post by pedro »
WEBLINK:
Takahashi EM-400
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
Has thanked: 1179 times
Been thanked: 1369 times
Re: Today's SUN (20181116) with good seeing
Post by MalVeauX »
Lovely work Pedro!
Post by MalVeauX »
Lovely work Pedro!
pedro
Post by pedro »
Thanks guys
Check out the artificial flat-field corrected moisaic image (TEC140 - four-pane mosaic)
pedro
Post by pedro »
Thanks guys
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Hi Pedro...
Very sharp images with all setups...excellent work :bow
The artificial flats produced a very even image as well.
Hi Pedro...
pedro
Post by pedro »
Thanks again guys
The artificial flat field is described here:
http://re.apaaweb.com/image_processing.html
ARTIFICIAL FLAT-FIELD (SUN)
Open mosaic image (16-bit TIFF file) http://re.apaaweb.com/flat_field_sun-01.jpg
Create a new Layer http://re.apaaweb.com/flat_field_sun-02.jpg
Create a Mask http://re.apaaweb.com/flat_field_sun-03.jpg
Copy mosaic image to Mask
Apply a Median Filter (e.g. radius 25) http://re.apaaweb.com/flat_field_sun-04.jpg
Reduce Mask brighthness (Curves) http://re.apaaweb.com/flat_field_sun-05.jpg
Apply Mask (Difference) http://re.apaaweb.com/flat_field_sun-06.jpg
Reduce Mask Opacity if needed http://re.apaaweb.com/flat_field_sun-07.jpg
Flaten Layers
Use Curves and/or Levels to adjust contrast and brightness http://re.apaaweb.com/flat_field_sun-08.jpg
Save flat-field corrected image (16-bit TIFF file)
Before/After http://re.apaaweb.com/sun_20111226_LUNT ... before.jpg
pedro
Post by pedro »
Thanks again guys
Flaten Layers
Has thanked: 8523 times
Been thanked: 8253 times
Another nice collection, Pedro. Lovely WL images with wonderful granulation texture.
Has thanked: 20738 times
Been thanked: 10437 times
That is an excellent set of images Pedro! Clear skies here too, but sun is low in the trees on the roofline for me this time of year.
pedro
Post by pedro »
Thanks Mark & Stu
It's raining here and you guys have the sunshine (low sun though)
best regards
pedro
Post by pedro »
Thanks Mark & Stu
best regards
