Dear All,
I still have some images taken on 2018 waiting for processing. Here are some of them. The solar activity was not much higher than now :-(
The seeing was quite good on July 1, 2018 :
Here are close-ups on the chromospheric network and inverse granulation near the center of the solar disk :
An image of the limb was taken with the 300 mm Newtonian and a G band filter on July 8:
Best regards
Christian
Ca K and G band images take on July 1 and 8, 2018
- Has thanked: 1 time
- Been thanked: 2713 times
- Has thanked: 1171 times
- Been thanked: 1360 times
- Has thanked: 9145 times
- Been thanked: 6025 times
Re: Ca K and G band images take on July 1 and 8, 2018
Beautiful images, Christian, thank you for sharing...
- Been thanked: 4340 times
Very sharp Christian...well done
Thanks to all :-)
Christian
Christian
- Has thanked: 20442 times
- Been thanked: 10247 times
These are excellent Christian! What focal length are you running at with the 2 closeup CaK shots?
Hello Mark,
The focal length is close to 3000 mm.
Thanks Christian. What are your experiences of the ZWO290M as a camera for solar?
