It was a beautiful late morning, so with coffee in hand I was able to enjoy average to slightly above average seeing and a wonderfully clear sky with perfectly warm weather. Wish I could get more days like this, lol.
It was also my first time experiementing with using the 'masked stretch' feature of Pixinsight to bring out the prominences but without blowing out the double limb, and without having to do a second exposure then stacking. I am a lazy astro imager, so anything I can do to cut down on work I'll do. Worked quite well, was able to preserve some detail and texture in the double limb, and didn't need to resize the main disc to cover it up or anything like that. I think this will become part of my standard work flow from here on, I think it just needs some fine tuning to eliminate the slight gradient difference just outside the double limb, should be easy to do in photoshop I hope.
Prom+semiactive region, and full disc from 05-26-20
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
Lunt ls100tha single stacked + hinode solar guider on ioptron cem26 mount
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- yltansg
- Has thanked: 1460 times
- Been thanked: 1447 times
Re: Prom+semiactive region, and full disc from 05-26-20
Hi Ammonthenephite,
With Earth there, the Proms looks really huge!!
Alfred
Alfred
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Wow, nice images.
Dan
South central Indiana
USA
USA
- Has thanked: 17949 times
- Been thanked: 17093 times
I don't think you're lazy. You just believe as I do. Don't do more then you have to. " Work smarter not harder " To be honest that is one of the biggest deterrents for me when it comes to solar imaging. It seems to be A LOT of work. However I would like to learn at least some on it so I could use it to help document my observations with my visual descriptions. I currently use GONG images. It would be so much better to use my own.
That prom is really tall. It's really apparent in your images.
What IS the double limb? Photosphere bleed-through or the spicule layer or both?
- Has thanked: 18092 times
- Been thanked: 8934 times
Wow!! seeing that prom on the full disc gives an amazing sense of scale, that is huge!! wonderful images
- Has thanked: 20940 times
- Been thanked: 10587 times
Really nice shots! Great view of the prom!
