AR2767 in High Res II | HA, CaK, Gband Trifecta | July 27th 2020
An archive of all the best images Solar Chat has to offer!
MalVeauX
Has thanked: 1179 times
Been thanked: 1369 times
Post by MalVeauX »
Hi all,
I had a small window this morning (0800am Eastern Time) here in Florida before clouds & rain rolled in. It's now thunder storming of course. But in that brief period I had a chance to get some decent data on AR2767. The spot has evolved a bit and the plage has decayed to something smaller with less major filaments coming from the area. Being close to the center of the face of the disc in its transit, some features are more obvious now (like cells, and the structures in the penumbra and sometimes the inner structure of the umbra itself). The plage is less dramatic and mottling less dramatic straight on compared to at an angle where more contrast is on the spicules. But straight on like this, the convection cells and k-grains are a bit more obvious with better contrast I think compared to at an angle. I noticed the beginnings of what might be a light bridge were different in the various wavelengths, in HA it appeared to have a nearly complete light bridge in two sections of the umbra, but I didn't see that same structure in Gband, but the structure's root to the umbra was visible, however in CaK it was a little less visible. Kind off as I have not noticed that before (with a completed light bridge I typically note it in all wavelengths). So perhaps it was not a light bridge. I'm not sure, so I'm interested in everyone's thoughts on this phenomena!
B&W:
Colored:
Seeing Conditions (not great, but supported the image scales of 0.2" to 0.4" per pixel with sub-arc-second-seeing):
Equipment:
150mm F8 Refractor
+ 2" Baader Red CCD-IR Block Filter (Sub-aperture internal D-ERF) + Baader GPC 1.25x (F10) + PST 1A HA Etalon + 10mm BF + ASI290MM
+ 2" Baader Blue CCD-IR Block Filter (Sub-aperture internal D-ERF) + 2.5x Telenegative Amplifier (F20) + EdmundOptics 430nm Filter + Baader 3.0 ND + ASI290MM
+ (aperture masked to 120mm F10) + 2" Baader Blue CCD-IR Block Filter (Sub-aperture internal D-ERF) + 2.5x Telenegative Amplifier (F25) + Lunt CaK B1200 + ASI290MM
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Re: AR2767 in High Res II | HA, CaK, Gband Trifecta | July 27th 2020
Post by dhkaiser »
Awesome images Marty. I leave comments on the light bridge to the more knowledgeable.
Dan
South central Indiana
USA
rsfoto
Has thanked: 9677 times
Been thanked: 5751 times
Post by rsfoto »
Hi Marty,
Very good and here it is raining due to " Hanna "
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Excellent images, Marty.
Awesome H-alpha and the WL and CaK shots are very crisp and detailed.
Peter
Has thanked: 17807 times
Been thanked: 16941 times
Post by DeepSolar64 »
WoW Marty! The Ha ones are good but the Gband and CaK ones are absolutely stunning. Incredible job my friend!
eroel
Been thanked: 4957 times
Post by eroel »
Marty, agree with James, the G band and the CaK are super.
Has thanked: 20738 times
Been thanked: 10428 times
A very good set of images Marty, glad you got something before the weather came in.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Hi Marty, excellent images - thanks vm
MalVeauX
Post by MalVeauX »
Thanks all,
Here's an animation (forgive me its a little large, 3.5MB, may take a minute to load) of the three wavelengths aligned to see how the structures change through the layers of the chromosphere and photosphere.
(If anyone knows a way to make these files more efficient for gif animation, that would be a great help, I can't seem to ever get them to be 500kb or anything like that, always several MB despite the files being only a few Kb each)
Animation of HA, CaK & Gband of the Sunspot and surrounding structures
christian viladrich
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Hi Marty,
The 3-band animation is very interesting !
arnedanielsen
Has thanked: 6276 times
Been thanked: 7288 times
Post by arnedanielsen »
Excellent collection of images in different wavelengths and the animation is just super cool!
Arne
Arne
Has thanked: 17888 times
Been thanked: 8887 times
Fabulous images Marty and that animation just tops it off :bow :hamster:
MalVeauX
Post by MalVeauX »
Thanks all,
Looks like something truly energetic is coming around the bend as of right now, it has a leading pore but the main spot is still masked behind the limb. It's magnetic region is significantly larger than AR2767's so this could potentially be a "great spot." Hope so! If it's truly "great" it may last the 10~12 day transit and make a 2nd appearance like the last great spot did? Would be nice!
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Top shots Marty !
Franco :bow
