Hi all,
Here is the image of the AR12770 in H-a I managed to take yesterday morning.
A light bridge is seen in it's glory. Seeing was really horrible all the morning session
and only one barely acceptable image in the result of 1 hour session.
Right Click on the image to open it in a separate window - to see it in full resolution.
Equipment used:
Meade 12" F/10 ACF
Full size 12" ARIES DERF
Quark Chromosphere @ F/42
Focal reducer 0,7x
Basler 1920-155 camera
Thanks for looking and comments.
AR12770 in H-a August 10 2020 with 305mm telescope and QUARK.
- AR12770 2020 08 10 Meade-12 ARIES DERF QUARK-0,4A @F42 Basler.png (1.24 MiB) Viewed 858 times
- Been thanked: 16694 times
Re: AR12770 in H-a August 10 2020 with 305mm telescope and QUARK.
WoW Valery. That is really good for the seeing to not be that good. What type of telescope is the 12"?
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
A beautiful image, Valery.
You still pulled out a wonderful result, despite the seeing.
Peter
Peter
Re-read my post. You can see that this is a Meade 12" F/10 ACF.DeepSolar64 wrote: ↑Tue Aug 11, 2020 3:25 pm WoW Valery. That is really good for the seeing to not be that good. What type of telescope is the 12"?
VaIery, I can't seem to remember what ACF is the abbreviation of. I will probably go duhhh when you tell me.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Terrific hi res!
Dan
South central Indiana
USA
USA
Hi Valery, an absolutely brilliant image, so well captured and thanks vm
- Has thanked: 8418 times
- Been thanked: 8163 times
Nicely done, Valery, under challenging conditions.
The light bridge shows up very nicely with good levels of detail. We can also see filaments emerging from close to the centre of both dark regions as this sunspot continues to decay.
- Been thanked: 8791 times
Wow!! that's a beauty Valery, I would kill for your seeing, well any seeing really
