FD and proms in HA and Baader Ca-K 29th January
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, not entirely satisfied with yesterday's results, illumination not quite right. There was high altitude haze but not sure if that's why. Usually I can get good overall illumination. Anyway these are taken with my Lunt 60mm DS and 80ed both with the Zwo ASI 178mm camera.
- PSX_20210130_195021.jpg (243.91 KiB) Viewed 786 times
- PSX_20210130_194844.jpg (214.31 KiB) Viewed 786 times
- PSX_20210130_194636.jpg (124.12 KiB) Viewed 786 times
- PSX_20210130_194620.jpg (306.05 KiB) Viewed 786 times
- PSX_20210130_194215.jpg (261.53 KiB) Viewed 786 times
- PSX_20210130_194002.jpg (92.56 KiB) Viewed 786 times
- PSX_20210130_193752.jpg (116.87 KiB) Viewed 786 times
- PSX_20210130_194758.jpg (69.78 KiB) Viewed 786 times
- PSX_20210130_193544.jpg (68.74 KiB) Viewed 786 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17969 times
- Been thanked: 17112 times
Re: FD and proms in HA and Baader Ca-K 29th January
You got much better results than I got yesterday!
- Stardust5858
Awwwww, thanks, it's really challenging this time of year with the low altitude of the sun and weather isn't it.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Hi Nigella, I wish that I could get such exquisite and fabulous images as you do - regardless of the weather.
Your coloured version of the "Two Trees & Hedgerow" prom and the undefined one in close-up are may favs...
Thanks vm for sharing
- Stardust5858
Awwwww, thanks Terry, very much appreciated.EGRAY_OBSERVATORY wrote: ↑Sat Jan 30, 2021 10:28 pm Hi Nigella, I wish that I could get such exquisite and fabulous images as you do - regardless of the weather.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9833 times
- Been thanked: 5831 times
Well done.
Well done.
- Stardust5858
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 20962 times
- Been thanked: 10597 times
Nice shots Nigella! Try sharpening the caK and proms at a smaller radius, you will get more detail out. Stopping down the ED80 to 60mm will tease out more detail too as spherical aberration is reduced, it will also be a lot more friendly to your seeing.
- Has thanked: 18105 times
- Been thanked: 8942 times
WOW!! look at that solar disc
Fabulous proms and CaK
PS Just wondering, all your images are time stamped with a 30th January mark, are they from the 29th or 30th Jan? However, somehow I can't see you imaging at 19:35. If you could correct that you would find it useful in the future, when flares occur or something special it is good to refer to the time stamp as you will never remember unless you write the time down somewhere else.
- Has thanked: 65 times
- Been thanked: 4462 times
Great series of images Nigella...well done
- Stardust5858
Thanks Brian, appreciate the comment.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
